Temp sending unit issue
Ohio
I just replaced my temp sending unit to try and get it to read on my gauge. I have a 74 but the engine is from a later year (not sure what year yet still scrubbing that plate on the engine). Should I be using the longer temp sensor or is the one pictured the right one?
There are also two wires but I know that’s for the emissions and I tested both.
The look pretty similar, I am just using the further back port. maybe I will try hitting that connector with wire wool to make sure there is a good connection.
Does the wire go directly to the gauge? I could just run a new one in that case to se if it works.
