- Thread starter
- #741
Is the solenoid on the LC's attachedd or external? If it's external, you should be able to turn the key on and jump the solenoid with a screwdriver. Can you push start it?
All the LC's are on the starter.
Your almost right, so branches will not get suck to the rack on top.I would think it would be so that small branches and what not would ride up the cables instead of just hitting the windshield.
I crossed a thread a while back that talked about the airsoft pellets to balance out the tires. The new coopers didn't feel well balanced since I got them mounted but with fighting all my other issues I didn't take it back to fix it. I think I'm going to pick some up and try it. Has anyone tried it?
https://forum.ih8mud.com/80-series-tech/241704-berthas-new-shoes-bfg-mt-km2-35-a.html
Today on the highway my check engine light came on and shortly there after the cruise control stopped working properly. A search in the 100 forum showed that another guy had the same issue and the code reader at Autozone said vehicle speed sensor.
Thoughts? Is there a way for me to check the codes like I could with the paper clip on the 62 or just bring to Autozone/Toyota shop for sure?
EDIT: Vehicle is tip top otherwise as far as I know.
I can scan it for you Marty I keep my scan tool in the 80. I think its a safety funtion because when mine tripped the light my cruise didn't work either it may depend on the code.
Does that scan tool work on taco ? Because my cruise does not work .
What was your code telling you?
Thanks Larry.
Now school me on the tool that checks the code. While I had the 62, I got into a habit of always checking the gauges and had to break myself of that when I got the 100. With these aging vehicles, I guess this might be a good tool to carry along.
. Disconnected the coil and turned the engine over and was introduced to a antifreeze/water bath from the sparkplug hole.
