Going down the highway, sometimes when I pass just over 80kph (~50mph) I get a funny, irregular, rattle from the transfer case. Its quite faint, but sounds a bit scary.
It goes away if you accelerate past 50mph (the band where it makes the noise is quite narrow, maybe 50-52mph) or load the case differently (I don't quite know if it happens most when its under heavy load, light load, or no load).
About half the time, if I press hard against the T/C shifter it'll go away, but half the time it won't.
I know worn idler bearings make the famous T/C whine, and while mine does whine, its actually far better than many I've heard. Can you think of anything that might produce a rattle in a narrow speed range?
