Tcase and front diff play question (video included)
I'm interested to see what others think on this. The slop that you show seems excessive. I have a 93 with 320000 miles on the shaft it has slop in the splines but just a tiny bit. Overall yours is a bit looser than mine. Question is what do you do about it?
Yes, if anything. The clunk going from r to d makes me anxious.
I decided to drain the diff... The plug was covered in metal
My '97 LX w/245K is the same.
Same slop in diff, same clunk going from D to R. Less noticeable on cold startup, more noticeable when diff oil is warm.
I just replaced the U-joints, pause in N when shifting D to R, and don't worry about it. No driveability issues over the last 2.5 years that I can tell. It's 20 yrs old with a gazillion miles :meh:.
Same as mine with 290,000 miles.
It's a little on the worn side, but not horrible. If you want to obsess about it, the first things might be new drive plates on the outer front hubs. I've seen worse. You just have to not kill it and stand on the throttle when going forward and reverse.
What Bilt4me said, oh, and that gray sludge on your drain plug is normal if your gear lube hasn't been change in a long time. Now if you had BIG chunks of gear teeth stuck to the drain plug, then you'd have something to really be worried about.
I would start by replacing your u-joints if there stock.....all other stuff seems normal with high mileage vehicle like others said...
Roger that. Thanks guys. The diff oil had about 3k on it but I have been in a lot of deep water. The metal bits were finger nail clippings and a couple of 1/2 bb sized chunks.
Ujoints definitely need replacing and I will replace the drive flanges too. The play there was not bad when I rebuilt the knuckles 5k ago. ...but, that was several offroad trips ago.
J
Stock breathers with water above them. I will run them into the cab at some point. ...the oil was a little grey, indicating a little water
Best not to run into cab as hypoid oil smells. Is that oily mixed water or gear oil contaminated with moly grease(internal seals)
J
This may be a good reason to stay out of deep water. The lip on oil seals point inward thereby stripping oil off the shaft, they are made that way in order to keep oil from leaking out. Most seals relay on a circular spring to apply a small amount of pressure to it's lip, in order to maintain continence contact with the shaft. The problem is, seals don't do a great job of keeping water from the out side, from getting inside when they are under pressure. So the deeper the water, the greater the chance water pressure will over come that springs tension, allowing water to leak in. So if your going to be spending anytime driving in deep water, you should set up a maintenance schedule to drain, and refill your axles, transfer case, and transmission after each swim. YMMV
There is no wear specification for rotational play. It is the sum of all of the clearances on the front axle: Ring and pinion backlash, side gears, pinion gears axle splines, birfield splines and drive plate splines.
The U joint seems to have some abnormal slop.
The counter rotational play at the wheels is about 4.
4 parsecs isn't bad.
