Taurusfan in a 2F'ish Pig?
Ooooh, pictures...I love pictures...so that's what I want ...good...is that the stock shroud?...looks very 'Cruiserfriendly...and 3 wires. O.K., 3 wires, can you run a 3-wire fan backwards easy like a two-wire fan?
Texican said:
Easy way to ID the fan you are hunting, and they are not only on Taurus, several FWD Fords use em
they have 3 wires, and are 2 spd fans...
Yes, three wires
Ground
Low
High
Very simple. I have a three position toggle switch: high - off - low. Mounted on the stock dash. A empty hole was there for some switch that I never figured out what it was for, so it became the fan switch hole.
The shroud can be trimmed also to narrow the thickness down a bit. A few pieces of aluminum strap mounted to the stock radiator braces and your up and running.
