Tank type engine block heater install, pics
Spokane WA, USA
I installed a 1000 watt Kat's remote block heater on my '96 LX450 and after an aborted install that did not work right, it now works very nicely. I wrote it up - you can take a look here:
Tank Type Engine Block Heater
John Davies
Spokane WA
Great writeup.
Why did you choose this type of block heater instead of the conventional type?
Great writeup.
I assume you mean a freeze plug heater - there are _lots_ of different engine heaters available....
The freeze plug heater is "supposed" to go under the intake manifold, and that is a real PITA to access. You can put it on the right side of the block, but that exposes the 120 volt power cable to excessive heat from the exhaust, especially if you have a supercharger. I don't have one yet, but maybe soon......
I like an external heater - if the element burns out it is easy to change. And if it leaks, it's a lot simpler to replace a hose than to remove a freeze plug. I guess that's the main reason I chose this type.... and it was cheap.
Pick whatever type you like.
John Davies
Spokane WA
Cool! I've been wondering about this type of heater for a while. It's nice to see one installed.
Warm coolant flows up to the Y from the heater tank, then through the control valve (assuming it is open) and through the cabin heater(s) and then into the cylinder head. If the valve is closed, the warm coolant will flow backwards, to the left in the picture, and down into the cylinder head at the Pesky Heater Hose (PHH) connection below the intake manifold.
One little correction for you though. The coolant flow is out of the head, through the PHH, up through the control valve, down through the U shaped pipe and into the heater cores. The heater control valve has an arrow on it showing the normal flow of coolant through it. Your plumbing set up is convecting warm coolant "backwards" through the system (against the flow of the water pump). Probably not a big deal, but with the engine running the coolant pumping up from the PHH will backflow through the tank heater.
With the plumbing set up the way your picture shows, the warm coolant can always reach the heater cores. The heater valve is actually controlling the flow of warm coolant to the PHH/engine head (valve open = warm coolant reaching the head and heater cores, valve closed = warm coolant only reaching heater cores)
I would switch the new Y pipe to the bottom hose so it is shooting warm coolant directly in to the heater cores, and so it is not seeing the "positive pressure" from the water pump.
:cheers:
P.S. I still haven't fixed my cruise control :whoops:
:cheers:
Thanks for the comments.
The cooling system on this engine is confusing, but regardless of how the flows go, this setup works fine. The normal cooling system won't bypass with this configuration because there is a one way check valve in the block heater. This is confirmed by the fact that my engine warms up to operating temperature quickly and the temp gage is stable under all driving conditions.
When I had the Y mis-located in the bottom steel pipe (the long fore and aft one) near the thermostat, the system DID bypass because the fluid flow direction was wrong - the engine's water pump was sucking cold coolant up through the block heater, so the the block heater's check valve couldn't stop it. The temp gage took forever to start to come up, and when I drove down a long grade the temp dropped. It was obvious that the thermostat was out of the loop.
Anyway, I made the mistake so you don't have to. Trust me - if you follow my instructions the system will work as designed, and you won't have to cut a section out of that OEM steel line ;(
John Davies
Spokane WA
$200 hmm, that's just enough to get and try out...even though I live in SoCal...and I really don't need it...but I do visit Mammoth a few times a year...hmmm, I think that is good enough justification...
Pffft, for you "because I want to" is enough justification. :flipoff2:
:cheers:
Hey everyone, I am wondering if anyone has done this on a LC 100 series. I have a 99 LC and want to do something similar instead of the freeze plug heater, PITA to install/fix if goes bad, etc. I'm a little confused on the your correction and if it would apply to the hundy. Was there any special process for refilling the system? Hoping to do this next week, please help guide a newbie to the customization world!
