<<Good news is I have a Jeep TJ sitting in the driveway>>
How can this possibly be good news?
LOL. No, I work on Point Mugu
Do you know Captain Mac? used to be there.
Navy Captain?
Never heard of him but only been here 2 years. No Marine Captains by that name that I have heard of either.
It actually connects to the cylinder head not the block.The PHH is a hose that connects a pipe on the side of the block to a pipe coming down from the top/rear of the engine. It doesn't connect to either of those pipes and doesn't go much lower than the head...
The more you know...![]()
Just order the silicone one sold here http://www.1fzfephh.com/Silicone.html
Read this thread https://forum.ih8mud.com/showthread.php?t=146598&highlight=PHH
I found the PHH not that hard to change (reading all of the threads prior was the key).
Good luck,
Riley
Yep, I ordered that one. Should get here in a couple three days. I'm lucky that I have a full work shop and every snap on tool ever made at my disposal for 2 bucks an hour. One not-so-wideley known benefit of being in the military. I've saved thousands over the last 18 years using those facilities.
Do yourself a favor and get some water-based lubricant (K + Y, Astroglide... your choice). It definitely helps with the install of the hoses.
If you have long enough arms and the right gear-drive, swivel box wrench, you can reach the middle bolt on the metal tube from underneath. After removing the top clamp and bolt, just loosening the middle bolt allows you to twist the metal pipe enough to get the new PHH in place.
Use caution around the PHH area. There is an electrical connection (knock sensor or something like that) that is prone to breaking.
Best regards,
Riley
I'm only thinking of buying an 80, and I have been reading these horror stories. I'm just sure that the moment I hand over the cash and turn the ignition that the PHH will rupture, the head will explode, and the birfs will crash before I get down the block.
Then again, I've hardly touched my 60 in the past 40,000 miles, and it is now at 213,000, hopefully I find an 80 that is surprisingly reliable with very little babying also.
after you fix it do flutter kicks...
