Rewired my cruiser from scratch. Everything is new. Everything is working right except the taillights. 66' wiring.
I have dual filiment single bulb lights. and a trailer converter inline. New brake switch and old turn signal switch. all tail and marker lights work fine. Front turn signals work fine.
The rear turn signals only work if the brake is pressed. brake lights dont work at all. ???? If I bypass the trailer converter with the brake wire and go straight to the light. Brake lights work. turn signals work, but when you use both the brake light over powers the turn signals obviously. That is what the converter is for.
but it is not working being wired per factory diagram. Everything seems right.
per diagram. power to brake switch and then out the the rear and also to the turn signal switch. power to flasher and then to turn signal switch.
What do you guys think.
