Hi all
This is on a 93 FZJ80.
I have searched and worked on this but can't seem to find the issue. Hopefully somebody can figure this out. Like others I lost my dash lights and then figured out my tail lights were out also. The tailight fuse was blown.I pulled out the trailer connector box since all the wires were cracked from age/cold since that seemed to be an issue for others. I also removed the green wire that crosses over to the other side. I went through all the wires/bulbs/fixtures in the rear and found nothing else unusual. I then totally uplugged the rear from the truck at the DS wheel well plugs to eliminate the whole rear wiring system. That didn't make a differience. My front clearance lights didn't work either so I checked the bulbs and wires and found no problem. I then uplugged the fixture from the truck to eliminate that.
So now I still have no dash illumination lights and still blow a fuse immediately upon turning on the lights just like before even though everything above is ulpugged. I don't have the electrical manual but do have the shop manual. On page 15 of the schematic you can see what I have been working with. I do have turn signals
headlights
Auto trans indicator lights in dash
brake lights
clock works
hazard lights and indicator blinks
heater sw speed button lights
rear heater switch lights up
antenna control has power
I have done no recent work/changes on the truck. Anybody have any other thoughts? As it is I can't really drive it since winter in Alaska is kinda dark and I need tailights. Thank you for any help you can offer!!!!!
akraven
PS where is the best place to get a EWD?
headlights
brake lights
clock works
akraven
