Build Tagged '67 LV build
What a process; hang, adjust gaps, install hardware, adjust again, install rubber trim, adjust, install frames, adjust
Been a minute since I posted. Had a bit of a lull in activity, but things are picking up now and I'll start getting some photos out soon.
In the meantime wanted to share something I thought was pretty cool. Found some markings on the inside of the cargo panels (markings may not be what they are, looks more like Gifu used a grease pencil, which for 50 years prevented surface rust on that area). Looks like my rig was USA #764!!! Which sounds about right if there were 1,000 imported and mine is a model year '66. Anyone speak Japanese? Would love to know what the symbol means! Shop has taken lots of photos to document location, size, etc. of these marking will full intent to replicate after painting.
Any help translating appreciated!
View attachment 2560210View attachment 2560211
According to my friend Akira Hiramoto it means "right" as in the opposite of left
Once again @xtremeVA has come through with some vital LV information! Thank You!
Because my door bottoms were replaced I wanted some information and measurements regarding where to drill. Given our LVs door bottom are prone to rust I thought others might appreciate this nicely detailed info, so here it is!
Drivers side front
41 - Driver side front drain hole meassurements wide view showing both holes.webp
42 - Drivers side front drain hole measurements from front of door bottom.webp
44 - Drivers side front drain hole details on measurements from back of door bottom.webp
