Here is the short story on my '97.
So I just replaced a lot of worn gaskets/ seals!! I needed it. Here are the gaskets I replaced: Dizzy, front crank, valve cover, spark plug, timing cover, oil pans... on and on. While the valve cover was off I replaced the PCV and hoses, etc. In doing so I even took the time to clean out layers of grime in my throttle body preventing it from opening/ closing all the way (wow that was bad!).
All of this work to stop one leak that I knew was coming from the valve cover rear and the dizzy. Anyway, I felt the need to change out other stuff while I was going to be under the hood.
So here is my dilemma (this obviously wasn't happening before the work). Ever since replacing and cleaning, my tach near idle has been acting a little haywire. When I run through first gear and let off the gas (NYC traffic), the needle drops WAY low below idle, almost 0 then bounces back up to idle then back down and back up to idle until it settles at idle after the second bounce. It continues to do this every time I de-accelerate in first gear.
Any ideas on what this new work/ cleaning has done? It obviously has been clogged for some time and now that the gaskets are working and the gunk in the throttle body is gone, it is starting to act a little whack! I figured it was supposed to help the truck, not hurt it.
Ideas?
Dave
Ideas?
Dave
