Creeker,
thanks for the kinbd kudos.
You are correct: We do NOT have a Fall Effect Sensor (FET).
Our OEM sensor is a simple 500 ohm pickup coil w/ magnet(s) on the flywheel.
It is NOT the var. ind. balanced bridge. as described by Honeywell. It *could* be, but I doubt it because there are definitely magnets producing the AC voltage.
On to discussing ISSPRO:
I called ISSPRO and talked with their engineering about the dial you mentioned: It will NOT work because they have a (undocumented) requirement for a *minimum* peak voltage that is too high.
ISSPRO could be made to work using:
A) A bunch of RS parts. This is not elegant or reliable and the whole solution is still on the pricey side for the gauge. I would probably also add a voltage regulator & support components. Now it is more complicated and too $$$ and I think I would rather just roll my own at this point!
...or..
B) ISSPRO said their waveform sensitivity could be adjusted, but you would have to remove the bezel to get at the circuit and you will destroy the case, void the warranty, make it look ugly... etc...Not worth it IMHO!
If you want to check with VDO and SW with the voltage & coil specs go ahead and let us know....
BTW: Pictured are my dial faces for 2H and 12HT and the ISSPRO unit - The RPM's are on target for what we need though.
Some other clarifications:
Hall Effect Sensors conduct in the presence of a magnet.
The coil produces current when the magnet MOVES past the coil.
The honeywell bridge coil changes inductance when a ferrous metal is in proximity.
I am also including the tach connections so that our Japanese brethren can help me decide what these tach wires are for!
I can guess red is 12V, but which is signal and which is ground?
Ie: "Hello, Mr. Mot-san!!! Please help decode this!
I am forwarding this thread to MOT. I hope he has a few seconds to help out.
- Eric
...or..
- Eric
