I'm currently building up a SBC 350 with SM465 tranny for my 73 / 40. I have started looking for a clutch kit and may go with a Valeo kit available from a local parts store, 11 " disk w/ low profile pressure plate. A GM throw out bearing is included in the kit (short style T.O.) Also have an alumiumum bell housing (5 1/8" opening) and the old cast style clutch fork.
Question: Most of what read recommends the toyota T.O. bearing. This is a longer bearing than the GM bearing. Why is the longer bearing used? Does this work best with the cast fork and necessary because of the operation characteristic of the toyota slave cylinder?
Some folks seem to get the GM clutch set up to work fine, and others seem to have clutch engagement issues.
Since this throw out bearing is included in the kit, I'm trying to get a good understanding of mechanically why it may not work.
I do know that AA recommends the center force clutch (11" diaphram clutch disk and low profile pressure plate with the Toyota T.O.) This supposedly works well, but why?? Anything special about the toyota T.O.?
Thanks.
Thanks.
