I've got an H55 + Toybox + splitcase in my Troopy. I'm thinking about installing a transfer case saver bypass hose. (I had the input shaft seal go bad in a different splitcase 10 years ago and it pumped most of the transfer case lube into the H41 wrecking the transfer gears fairly quickly.)
The bypass hose usually goes from the fill plug on the trans to the fill plug on the transfer case. Would it be a good idea to install a "T" and connect the fill plug on the Toybox too?
