I am getting ready to pull the t-case on my May 78 FJ40. I am going to pull the trans and t-fer at the same time as one whole unit. I have been told it is easier to build and stab back in as a unit.?? I cracked the case at Katemcy TX and I have a doner case from a 79 FJ40. I am going to have to use parts from my case to complete the doner csse. Will all of the parts interchange with this case? What do I need to look for in this swap. I have never done this and will be calling on a few of my more experienced friends for help. Any info would be greatly appreciated! Trying to get it ready for GSMTR! (got to).
I did it as one piece just last weekend. It still helped to have someone with me to help rotate the tranny a bit to get it lined up on the garage floor. Also have an extra hand to get the bolts threaded.
I did mine as one case but recently had to pull the tranny and xfer a couple times (another Katemcy incident). Found it easier for me to pull the xfer the pull the tranny. But I was working alone too. In fact just got it done today.
The parts should interchange - at least Specter's rebuild kit for the '78 also covers the '79. There is a seal difference though that lists 068-03A #3 TFR SEAL-1958-8/78 4.80 and
068-03B #3 TFR SEAL-8/78-1/90. This is the little shifter seal in the top cover. Guess they're different but you can see that having examples of each at hand.
Overall it's a pretty straightforward assembly that won't go together wrong. It will, however, let you get pretty far along the wrong way before you realize that it ain't gonna' work so pay attention when taking it apart.
There are differences of opinion as to whether it's easier to take out the trans/transfer together or apart. For my money I'll take them out together every time because of the potential hassle in splitting them. I'd rather chose my own ground for hassling.
I made two headless bolts to use in guiding the transfercase back onto the trans. I've always made them for cylinder heads and it made sense for this too in order to help keep that seal from being damaged or misaligned by crooked going. The book lists a Toyota special tool for this but who has one of those?
The seal goes FLAT SIDE TO THE TRANSFERCASE, spring side to the tranny. And be sure that that seal is fully down into it's place or it WILL leak. There's a lip that the flat side seats against. It can be seen best from inside and the seal needs to be flat down to that lip ALL THE WAY AROUND. This would be easy to do wrong and THINK that it's driven home while it's still got a few thousandths to go in one section or another. Crooked seals leak almost every time.
I have done it both ways and really think it is 6 of one 1/2 dozen of the other. Honk is right on with the guide bolt idea.
A couple of thoughts:
It is very easy to mess up the seal on the back of the transfer when installing it. Do not let the TC hang from the tanny shaft! Grease that seal up just like the gimp!
The overall lenght of the tranny and output shaft can make it very akward to stab the TC on. Remove the bellhousing motor mounts and lower the motor a bit. Makes life much easier.
