Synthetic winch rope?
3/8 Dyneema. Rugged stuff.
I just added a 12000 lb winch to the 80. If like to add a synthetic winch rope. What kind of rope are you guys using?
I've got the rope for my 12k winch on here from Southeast Overland - 80 feet, 3/8". Truck has remained a mall crawler, though, so no experience with this in action.
I suppose I should upgrade my Ramsey on the K5 from steel...
Is it a HF 12k winch? If so the synthetic line is a bitch to get into the lame hole in the drum. Every other winch uses a crimped eyelet to secure the synth rope. HF uses steel cable so it's just a hole and a set screw for the cable.
You can still use the crimped eyelet, just has to be drilled out a bit and you can use a 12mm head bolt to secure it to the drum.
I have a HF winch. The original steel cable slides through the hole in the drum and there is a small set screw that holds it in place. That threaded hole for the set screw is what you can use another metric bolt to attach your synthetic winch line to.
Argh!!!!!!!
Damn I'm dumb. I'm usually not that dumb but fawk I'm dumb. I did not think of that!!!!! :(
I have HF 12000 winch, and replaced with 3/8 dyneema rope. The through drum shaft hole is even more convenient than the screw tap type. Just wrap (1 wrap) the synthetic rope with duck tape about 4-6inches in lenght, shuffle it through the feedhole, put the screw back. The screw is hex that tightens below the drum surface. It wrap around drum smoothly, just make sure the rotational direction is correct.
Yeah, 3/8" amsteel blue. It's about 100' on the spool (m12000). I also have an additional 80' or so as extension, plus a tree protector (you can never have enough rope...). Use an aluminium hawse as well. Pic below when it still had the rollers instead of the hawse (I did make sure the rollers where 'smoothed' due to prior use with steel rope), went to a hawse the next season.
The synthetic is fantastic to handle, especially in the snow. It's easy to wrap around the bumper if you plan to use the winch a bunch more times. It IS surprisingly strong since it's hard to imagine plastic not snapping instantly under load :)
cheers,
george.
Used the SouthEast Overland rope and did the same electrical tape "trick". It was a no go.
Steve at SouthEast Overland said he just wraps the drum 4-6 times and duct tapes the wraps to the drum. If you get that far down your spool and you're close to exposing your attachment point you're about to have a bad day.
I have the same winch.
Most likely fine but a good mechanical connection point is always betterer.
Here's SouthEast Overland's sub-forum. Always good to support the vendors on here. Give them a call and they'll get you fixed up.
Southeast Overland
I snapped my steel cable at Coal Miner this year and they just happened to be there onsite to hook me up with a new synthetic rope. Definitely good guys.
