Switches
Vancouver, BC
Website
www.flickr.com
has anyone found any switches that match the stock ones?
I'm looking to add some lights and redirect a set of winch controls in to the cab. I guess I will need standard on off switch for lights and a rocker switch for the winch (forward, stop, reverse)
Thanks in advance...
I don't know of any, but I would imagine at least Toyota should be coming out with some. Even the fully equipped FJ's have blank spots. Gotta be used for somthing!
i checked toyota dealer they have no auxilary light switches for the fj. im checking into the 95-98 forerunners they had fog lights with rocker switches and i think they will fit in the fj blanks . i will let you know!
03-07 4Runner/05-07 Tacoma/FJC/GX470/LX470 all use similar aux/accessory switches.
*note that Tacomas have a orange-ish backlighting, and others have a yellowish/greenish backlight, while others have a straight yellowish backlight!
The switches are very expensive. Fog light switch is like $70 alone...
**oh and for a oem rocker, not sure but the GX470 has a variety of switches- one might be a rocker. gotta pay to play for a all-oem look tho :(
Don't forget that you can get a steep discount on OEM parts, including those switches, from Cruiserdan. I'm not affiliated with him in any way other than being a satisfied customer. He's the parts man at American Toyota in Albuquerque, NM. I think that if your order is over a certain amount ($50??), you won't even pay shipping. You can PM or call him for price quotes.
The Taco switches will work, I have two in the switch bank to the left of the steering wheel. I use one for my fogs and one for teh driving beam of my IPF hybrid assist lights. You can purchase the switch, connector and 4 wires that fit into the connector for around $50 from trdparts4u. There are four terminals on the switch: power for switch (usually tapped off marker lights), line to relay, illumination circuit for switch light and ground. Here is a link to the write up I did. It has the part numbers:
http://www.fjcruiserforums.com/forums/showthread.php?t=5695
Jay
I like the look of this one and am willing to pay the $$$ for the switch to keep the clean look now I just need to find a rocker for the winch control that look as good... there has to be an OE supplier out there some where...
