Switch Light replacement
Palm Harbor, FL
I've searched and come up empty handed. Is there a way to replace the lights on the switches in the cruiser.
My hazard and antenna switches are out. Would like to keep them all lit. Any help is appreciated.
Its pretty easy on the switches, dash bulbs behind the D etc are harder.
Pop the switch out and on the backside you will see a screw driver hole, twist that a qtr turn and the bulb comes out, get a new bulb and put it in.
You can take a bulb into your local dealer and they may have to order one. I would get a few while you are at it. They are all the same bulb.
I had a few lights out when I bought my truck, pulled the bulbs out and they were fine. I got them to work by giving them a good, solid whack by the bulb holder! They lit up and have been working ever since.
HTH
Daisy
Thanks for the replys. Sounds easy. Going to pull and replace. Daisy I am going to try the "whack" method. :)
