Switch Bulb Replacement?
Brentbba
Former Golfer
OC, CA
Backlight bulb on my rear defroster switch has burned out. Noticed it after I'd installed the new Center Dif Lock switch next to it.
I haven't pulled the switch yet to look, but are the bulbs in these replacable? Ifso, Dan probably has a couple hundred in stock that he's going to have to count at the end of the month and I'd bet that my local dealer doesn't stock them. :flipoff2: No desire to pay out $$ for a new switch.
Yes, you should be able to get them from Dan
Thanks for the pic James - wish I had more than one damn bulb to order tho. Just fed his dogs a week or so ago.
Brent,
Depending on the switch, it probably has the tiny green "condom" on it. Most of the bulbs are white from Dan. When you remove the burnt bulb, gently slide off the greeen sheath from the old bulb and slide it on the new one.
-B-
