Swayaway Torsion Bars
Just ordered some swayaway TBs this week and got it tonight. Couple things I’ve noticed when ordering and seeing what I received.
First is that Swayaway website and tech support states the bars are 32mm instead of 31mm. Second, it’s black powdered coated now vs red. Not sure if it actually increased from 31 to 32mm. Guess if mistype, oh well. If it increased, not sure what that actually means. Maybe increased spring rate? The color has definitely changed to black. The color doesn’t really matter to me but something noting a change.
Also, swayaway did some markings on the end of the bars and splines to make it more easier to identify Left and Right sides and the direction of the indexing. I didn’t see this from previous threads (I could have missed it). Thinking this will help during installation.
Anyway, just wanted to share. You all let me know if you know something more about this.
Here’s the markings (notice the arrows and L and R?) along with color coding (green for left and white for right) on one end. Not sure what “N” (or “Z”, depending on how you look at it) means. The other end is blank with no markings.
Will these particular t bars fit LX470 2000? Just not sure what late models in description mean
should fit fine... not a bad idea to throw on some Ironman4x4 Torsion Bar reinforcement brackets while youre in there.
Easy to install, and only costs a couple lunches.
There’s apparently little size difference among those two not sure how much of a difference would that make?
also any idea about OME 2865 & 2866 rear coils 2865 comes up as compatible for 2000 models but 2866 doesnt. Someone on other forum suggested 2866 should fine too. Suggestions pls
Decided to go with 303001 and 2865 for coils. Sway away might get little too stiff
