Sway Bar Rubbing Control Arm
Costa Rica
On my 97 1hdt
I think I have this sorted but looking for some confirmation before hunting down a sway bar.
Seems like the front sway bar may have taken an impact causing it to rub the control arm pretty hard on the right side. The left has clearance. Could anyone snap a photo of what the right side of theirs looks like. Or tell me how much clearance on each side is normal. I purchased the vehicle like this and am getting ready to replace the suspension. The stock suspension is nearly sitting on the bump stops from 250k km on dirt roads.
Seems like an impact is the most obvious answer (that side even looks out of wack to me). If it's relevant, the control arm bushings on the opposite side (left) are in need of replacing (rubber has released from metal on one or two and they are just worn out), im sure the right side are not good either. Those will be replaced with the suspension upgrade but I'm trying to track down all the parts I need and do it all in one shot, so if I can confirm the sway bar is bad that would be great.
Thanks!!
The problem could just as easily be one or both radius arms are bent. With those you can generally eyeball it by looking down the length of the arm to check for straight-ness. I have bent them from off road shenanigans, it doesn't necessarily take a collision.
@Zach R 86
Are you lifted? If so, are you running a stock panhard? To me, it looks like a lifted rig that didn't recenter the front axle. (Take a look at the end links... they look like they are being pulled) If that's the case, an adjustable front panhard would solve your issue. For the short term, pull that sway bar off and run without it. Once you get everything figured out, you can throw it back on. (or not!)
Yeah i had that thought, they look perfectly straight by i will put a straight edge on them to be certain. That was sort of the reason i was wondering about worn out radius arm bushings being a culprit.
@Zach R 86
Yes I totally agree that is the scenario that would normally cause this. However this rig is not lifted, rather it is sitting on beat to hell stock springs. The front left sits lower then the right, and the axle is visibly a bit off center to the right. My first thought was to put on the new suspension and fresh bushings and see where things are at that point. Which I will be doing once items are able to be shipped into our country again, but still would like to understand what is going on. Seemed like the axle straightened out when i jacked up car a bit to simulate a lift/stock suspension height. The springs are so bad that I believe it is nearly riding on bump stops when I have passengers.
Crazy... so maybe you're 2" lower than stock and the panhard is pulling the axle in the opposite direction? Get a center of hub to fender measurement to confirm...
Yeah maybe, I will check that tomorrow. Even with it up higher using the jack, the sway bar still looked way too far to the right. Next time I see an 80 on the road I will be flagging them down to compare haha. Ive driven trucks without the sway bar in the past, but I feel like with the weight of an 80 and how bad the springs are, for safety I should leave it on until I have another, even if it's rubbing.
