Sway bar bushing kit?
Missoula MT
Hi all I want to replace all the bushings that go on the front sway bar. Was wondering if there is a kit you can buy. Or if not what would the names of the bushings be?
Thanks
Nice thanks. Is there any more bushing that can be replaced on the sway bar?
For the front sway bar I installed Energy Suspension bushings, part# 9.5112, 1 1/8" (28.5mm), it comes with new brackets which have to be used (the OEM are too small).
I put a total of 4 on the front sway bar when I did mine
Do you know what the others are called?
Sway bar bushings.
:meh:
Here is a pic from SOR. you need #991 (2) and #61 (2) in the picture.
IIRC the rubber insert for the ends are same front and rear
If someone could verify this that would be great. My rear ones are loose and I'd like to replace them.
I'm not sure if they are the same, but they are sold under different part numbers:
Front Stabilizer bar bushings (x2) 48815-60070 $7.84/ea
Front Stabilizer bushing brackets (x2) 48823-60030 $5.01/ea
Rear Stabilizer bar bushing (x2) 48815-26020 $8.14/ea
Rear Stabilizer bushing brackets (x2) 48823-60030 $5.01/ea (same as front bracket)
I just replaced the rear ones. Haven't got to the front yet, but got all four in one bag. All most positive they are the same front and rear. The metal tubes/sleeves are the same as well.
The sway bar links are different front and rear though.
If the part numbers are different the parts are different.
Maybe you need a new parts guy?
I replaced mine with the energy ones. I personally do not like poly bushings, but I feel like for the D-shaped swaybar bushings, they are a bit better than the OEM rubber ones. I for some reason couldn't stop the OEM ones from migrating open at the slit. The sway bar kept working through the bushing and making contact with the frame.
I finally got around to replacing them. The brackets are exactly the same, but the bushings themselves are absolutely different.
The fronts are stamped with a "29" on the side and the rears are stamped with a "25" and the inside diameter of the rears are noticeably smaller. I measured the rear and front sway bars themselves and they are 25mm and 29mm respectively. You might be able use the fronts on the rear, but why not just buy the right size? :meh:
i think there's confusion here. there are four bushings per bar that need to be replaced. two D shaped bushings are held with the half circle brackets to the axle housing in the rear and to the links in the front. the other two bushings go in the end of the bars themselves with metal sleeves and bolts go through them.
the four tube bushings at the ends of the link bar themselves are the same front to rear. the D shaped bushings that hold the bar are different.
This
