swapping front springs--real time help?
Pennsyltucky
Can someone tell me if I need to disconnect the shock to swap the front spring from side to side? i have the truck on jack stands just behind the control arms, the wheels are off, and the front axle is unsupported. What's next?
Thanks!
you should be able to unbolt just the shock bottom and jack up on the opposite side, then remove spring. Unjack, move jack to side you just removed, remove other shock bottom, jack up other side, swap springs, attach shock on side just swapped, move jack to other side again, put shock in, jacking on opposite side again as needed.
got it--thanks--next question--what's the spec for tightening the bottom shock bolts? and it there is no difference side to side for the OME shocks, right?
thanks!
Right, no difference.
I just go by feel though... yeah... that feels tight.
it's a Nyloc IIRC? if so, just enough that there is no play and not so much that the bushing is squashed excessively...
(OK, that is somewhat subjective...)
got it guys--thanks much! just did plugs, wires, dizzy cap and rotor, spring swap (the trucks sits much more level now!!) and about to go through landtank's axle check.
sweet !
next time will be starter and O2 sensors.
:beer::beer:
