SUMOTOY said:WE
I'm curious how 59 and 66 differ. They shouldn't
try reading - I know it's not your strong suit - from post 66
" changed one of the assumptions from dropping the axle brackets and putting the axle where it would be without dropping them to going out the full arm length and then dropping."
SUMOTOY said:I'm curious how my drawing 118 is "wrong". You even used it. I'm curious how your CAD got picture 101, it doesn't reflect the proper axle mount or arcs (specifically it's missing lift axle pivot).
what the hell is a lift axle pivot? Ya', I used 118, but I think you're looking at the picture wrong. How can you not see that the black arc and the green arc aren't the same path?
SUMOTOY said:I'm curious how your cardboard only addresses a single rod on a dual rod articulating axle. I'm curious how your cardboard arcs don't intersect properly to reflect axle lift..
One last time - we're not looking at articulation. We're only looking at the path the axle takes - do you understand this or not? You do NOT have to look at both sides to understand or simulate this. The cardboard arcs DO intersect properly. There is only one way for two arcs, of the same raduis with those two mounting points to intersect. Guess what, they'll intersect 180 degrees from there too! The orange is for a leading arm - or radius arm mounted lower on the frame. The black is for a leading arm mounted at the stock location on the frame. You can see where each is pivoted by the pin. You can see that each has the same amount of lift by the lovely green springs that put the center of the axle, the little black circles, the same distance vertically from the frame. You can see that the arms are the same distance, cause it's the same darn piece of carboard to represent the leading arm. Let me rephrase that, everyone else can see that...
SUMOTOY said:I'm a curious guy by nature. I can handle you being pissed off.
I'm sure you're happy to think you've pissed me off. That's the whole reason you keep posting the way you do and continue to use WE after I've asked you not to. Maybe I'll start refuring to you as DS.
SUMOTOY said:I don't think you have much of this right, nor are your posts consistent. To help educate a "clueless" guy like me, you can:
* make your posts consistent (and continue to delete the others)
My posts are consistent. The only ones that I changed anything between, I said why right in the post! The only ones I've deleted is because those are the ones that I swore in.
SUMOTOY said:* correct my geometry and conclusions in 118
* reread the givens in the story problem to see my posts as
consistent
* Use Cad to 'fix' 118 *and* come to a different conclusion
regarding articulation arcs of 2 static level axle rods. That should
also disprove my articulation arc formula in the lower right
I've already corrected your conclusions.
Yes, you're posts are consistent - consistently vague, consistantly wrong, and consistantly misguided.
I don't know what you're trying to prove by the arc formula in the lower right, but it certainly has nothing to do with the topic of "Does an axle with lifted axle mounts take the same path through it's suspension travel as a dropped frame mount?" Which the answer to, in cause you didn't read it another posts, is NO.
SUMOTOY said:There's a lot of folks watching this thread. It might be nice to get it cleared up? Since you keep wanting to 'add' to 118, not claim it's wrong, why don't we start there?
Thanks for your continued efforts on behalf of this ascribed clueless
Scott Justusson
I'm not adding anything to 118. I'm just saying you don't know what your looking at or your trying to answer a question that no body asked, and nobody else seems to know what that question is. Seems your trying to prove that for whatever amount the right front wheel goes up, the left front wheel goes down. Which is just silly.
How about you start by answering the questions I've already asked?
"what suspension have you ever designed?"
Here's one more for you.
1. What determines the path that the axle moves as it goes through it's travel (80 series front)?
If you can answer that one correctly, we'll move on. ok DS?
