Suspension question....
London UK/Ruston Washington
I have already had the old girl off road and have been insanely impressed with her performance. I am intersted in getting a couple inches of lift.Perhaps 2 or so maybe 1.5. Anyway...just wondering if there is a Shock out there on the market that will achieve this without replacing springs and such. I met a chap who had a nice 4 runner that said that I can get 2" of lift just with shocks??? Anyway..if this is so I would love to know who makes them and if anyone on here have done this without spring replacement.
Thank you guy's-Andrew:)
Actually I'm not so sure of that. Some shocks come preloaded, and you have to work to compress them enough to install, so they would technically make the truck sit higher.. also shocks with higher dampening would mean your truck compresses less than it would have with a shock with lower dampening.. neither one would be that significant though. :meh:
Why not just do a quick spring lift? Or spacers, if you need to stay cheap. :confused:
edit: I had a buddy a few years back who had a Blazer, and he put some Ranchos on there and the back end was easily 1" higher than before, rode stiffer too. So I've seen it happen..
A shock wont give you any lift. If it did it would give you an unbearablely stiff ride, basicly you'd feel like there wasn't even a shock at all. go with the ome medium kit. you'll love it.
Nakman's right on the money.
My Procomp shocks gave me about 1/2" of lift compared to the OME shocks. But the OME shocks preload is incredibly low.
If you don't mind a super stiff ride you could get a set of shocks to give you a mild lift, but you'd be further ahead by going with another option (body lift, suspension lift, spring spacers, etc). They would also not bolt straight in, and likely be on the expensive side.
A body lift and MAF spacers all around will set you back around $200 and bolt striaght in. That could easily give you over 2" of lift (1" body lift and just over 1" for the MAF spring spacers). Any shocks that give you 2" of lift will be expensive as you will probably have to buy some that are rebuildable with an adjustable preload. And you'll have to deal with the stiff-as-a-board ride.
You do not want to use your shocks as weight bearing members for your suspension. They are for dampening movement, not supporting the weight of your rig. It puts unneeded stress on the mounts, which aren't designed to do the job in the first place. Also, it has a negative effect on the handling. There are air shocks and many "new" products that will advertise cheap or quick fixes for your problems or dreams of performance. But in the end, you will end up paying more for these quick fixes. Stick with proven products that don't alter roles of your suspension parts. Generally for lifts, both the springs and shocks need to be addressed. And that's just the beginning, but the FAQs here on MUD can better help you.
Shocks take some of the weight of the rig. How much they take is determined by preload. Even with the incredibly soft OME's, there was a (very slight) drop in height when I unbolted them. Hardly anything, but they did support some of the weight of the rig.
Shocks are not the same as a steering dampener. While their basic design is the same, their purpose is different. A steering dampener truely has zero preload, and will not support any weight. This is why you cannot use a shock in the place of a steering dampener, otherwise your rig will always want to turn right or left.
For some vehicles this may be an issue, not for 80's. We have a huge bolt for the lower rear shock mount and the upper rear shock mount is doubled up (nearly) quarter inch steel, meaning you have almost half an inch of steel there.
The fronts are also equally beefy, while they're not half an inch they are more than beefy enough to support a huge amount of weight.
The mounts could easily be half the size (or less!) and still be adequate for the amount of weight that is put on them. Even if you put in incredibly stiff shocks.
Again, not necessarily true. I've found that stiffer shocks improve handling greatly. When I swapped my extremely soft OME's for the much stiffer Pro Comps, the handling was vastly improved. Lots of people have reported similar results with the Bilsteins, which are also stiffer than the OME's.
In fact OME's latest gen shocks are stiffer than the classic ones, one of the reasons is for improved handling.
If it had a negative effect on the handling, then race cars would have Cadillac like suspensions. But they don't, the best way to describe them would be "stiff as a board." The ride sucks, but the handling is excellent.
Mr. T has actually used air shocks in the newer gen land cruisers to give them about an inch extra of lift. They're not exactly "new" products, nor are they cheap.
They work, and are very cool, but IMHO they're not worth the expense.
Ebag, in theory you are right. I dont think anyone will debate that. However, for a shock to support enough weight to lift the 80 series 2 inches it would be pretty much useless as a shock. thats what the op is asking i think. A shock does support SOME of the weight but what it supports is minimal. A spring is designed to carry the load and the shock is designed to dampen the springs movement.
I'm not sure you could find a shock that'd lift our heavy trucks a full 2" (without getting into adjustable air shocks, etc). But 1/2" to 1" over OEM/OME isn't unreasonable, and the shock wouldn't be useless (though relatively stiff).
It all adds up. An inch here, an inch there....pretty soon you're talking about a real lift. ;)
80tOylc is correct. The shocks that will change suspension height are air shocks or NIVMAT shocks that came on late model GM Suburban/Tahoe style trucks and SUVs. Buy some coils or a spacer kit. You can put 1.5 to 2 inches and not suffer any suspension problems. FabTech and RevTek are building some pretty good toyota lifts.
need help ....im planning to put 35x12.5x15 on my lexus lx 450 do i need to lift?? and do i need to regear? thanks
Lift: yes, you should lift it according to your intended use. As pertaining to a re-gear, that is up to you. I have 35's with stock gearing and have no complaints. If I were to tow a trailer often, I would consider re-gearing.
You can probably fit 35's without a lift, but you'll have little to no flex and may even rub driving around town.
I have not regeared my truck, and I occasionally pull a 3k lb boat. It's slow on the hills when towing, but I haven't had an issue with it otherwise. :meh:
This has been my experience, the power is there even with stock gearing.
