Suspension Question, Need Opinions
SE Mo
Hey there, been working on the Cruiser I bought off E-Bay, and I got some questions. Its a 77 FJ40 w/350 conversion, with an Advanced Landcruiser Handeling Systems shackle reversal kit on it. Who ever put it on didn't weld it, just bolted it on. I'm fixin to weld it, but was wondering if there would be any advantage to reversing the front hanger to were it slopes to the rear as opposed to hanging straight down like it does now? The reason I ask, I went back thru the search feature looking at shackle reversals trying to learn a little bit, and came across where someone was doing it this way ( Man A Fre kits I think ). Considering some of the other things I've found on this Cruiser that some PO did, I'm just trying to get it straightened out so it will be dependable. Thanks for any advice/help. Al
Good question
I also have the same shackle reversal kit, welded on. At the time, it was the only 'kit' available.
Since then, I hear that other kits are available, that still return the caster to normal, but aren't such 'rock grabbers' as the original Advanced Handling kit. If I had the choice that you have, I would consider using a different kit that wouldn't impede the approach angle so much.
As to your specific question, I can't answer it directly, but I can understand why you'd ask it.
I can't recall if the front springs are swapped ends as part of the LCAH install. To do what you suggest might require the front frame horns be lengthened to allow the spring eye to end up in the proper spot on the fixed (front) end.
the Advance Handling kit can be bolted or bolted and welded on.
this is the MAF SR on my 45, very happy with it.
I don't see why you couldn't reverse the LCAH kit...I used to have it too, bolted on. However, it will also mean relocating the shackles on the frame, since it will push the whole pack back ~3"...AND it will mean reversing the spring packs end for end, to keep your axle in a relatively stock position.
ian said:
Ooh.. now woody has a Toyota katakana avitar! Secret society? ;p
I think it is the "group" that Woody would not let me in ;)
Redesigning the one you have right now would be a PITA. If I were you I might just do a SR using the stock spring mounts and then make new spring pads. It appears that you have the ability to weld so I think you are set :)
Besides, it wil be easier to go SO if you do the SR properly now ;)
More Info
Thanks for the replys, Guys. Here's a little more info, please excuse my terminoligy if its wrong, still learning. In reguards to the springs, it has 2 metal bands ( military wrap? ) around the back half which has the moveable shackle, and one on the front half. Also, when running this kit, do you need a long travel front drive shaft? This thing won't see any rock crawling, etc. Just a weekend cruiser, and hunting vehicle. Thanks Guys, keep the replys coming. Al ps- How much difference is there between the MAF kit, and the ALCH kit? Thanks
those metal bands are just spring clamps....single on the short side, duals on the long side. Military wraps are actual springs, where the 2nd leaf of the spring pack wraps around the eye of the spring. Mil wraps are a generally either at the solid-mount end of the spring, or at both ends. On stock FJ40 springs, the short-side has the mil-wrap.
Long travel front shafts are rarely needed for SUA suspensions...but it's possible.
