Surface Rust?
Atlanta, GA
Is there really such a thing - in the real world - as just surface rust on a 40? I've been looking for a month or so, and lots of owners claim "surface rust". It just seems like surface rust is something that would be very difficult to diagnose, especially if it's under paint (in the ads it frequently is). If anything, rust under paint makes me more suspicious. But I don't claim to have any body repair expertise...
There happens to be a blue 40 on the 'bay right now in SC that makes an excellent example. Maybe some of you pros could look at it and give me your opinion (not sure if live links to ebay are allowed here)?
why yes they are, some of them provide good comical relief for us on less productive days
Surface rust is the part of rust that you can see. Rust is like an iceberg.
Rust often gets fully developed under paint, invisible until the paint begins to bubble.
Great - so everything short of all out cancer/rot is surface rust...
Which basically means that EVERY 40 has AT LEAST "surface rust".
I guess I now have a new definition of surface rust.
I too would be suspicious of "surface rust". if a panel is rusting from under the paint it would indicate paint failure. My '78 fj40 had lot's of rust that was started at the body joints, where there was likely never much paint to begin with, and the seam sealer,I'm sure, dried up in the 1980's. This metal rusted from the back side to the front, starting with the tell tale buldge in the panel that indicates rust in the seam between the metal. the only real "surface rust" was under the undercoating, and around the gas tank where dirt had accumulated, holding moisture near the body. If a car really has surface rust (rust under the paint), the paint needs to come off, then acid wash, then metal conditioner, then epoxy primer.
Believe it or not in Arizona we do have surface rust. I put a small dent in my 68 years ago (over ten), pounded it back out and sanded still haven't put any primer on it. I have made sure that I keep it clean and there is no problem keeping it dry. So far I have a little surface rust that shows no signs of pitting. But if you have bubbles showing in paint that usually means the rust is coming from the other side. To me if it shows bubbles or pitting it is not surface rust.
John
I think people say 'surface rust' to soften the blow of the reality that what they have for sale is a rustbucket POS. Kinda like saying 'a little cancer' or 'cigarettes aren't really that bad for you'. I like the iceberg analogy.
