Surepower Install
Brentbba
Former Golfer
OC, CA
Romer - info to perhaps add to the FAQ on dual batteries using the Surepower. Sorry I forgot to take pics before I buttoned the dash back up. Warning - this is on a '94!
To use the automatic setting on the Surepower dual battery solenoid setup, the instructions say to tap one of the leads from the control unit to the starter wire. Thanks to a wiring diagram from the FIL, I knew it was a black/white wire. It's position #22 at the ECU, but that's NOT the easiest place to access. Way to many wires and I didn't want to mess around with any of the wiring bundles there. It's also in Position #5 IIRC on a molex connector directly under the ignition switch that's accessable by removing the lower dash panel under the steering wheel. The black/white wire there is readly accessable. It's a 12-14 guage wire. Be sure to test at the molex connector first to confirm. Voltage should be on that wire only with the key in the start postion. Simple double check with the voltmeter (yes, I do own one Dan).
The wire runs out of the molex connector into a wire bundle headed to the DS of the truck. I used a crimp on connector to tap the wire.
Hey Brent,
What kind of Surepower are you using? Are you talking about the 1315-200 solenoid?
Thanks to a wiring diagram from the FIL, I knew it was a black/white wire. It's also in Position #5 IIRC on a molex connector directly under the ignition switch that's accessable by removing the lower dash panel under the steering wheel. The black/white wire there is readly accessable. It's a 12-14 guage wire. Be sure to test at the molex connector first to confirm. Voltage should be on that wire only with the key in the start postion. Simple double check with the voltmeter (yes, I do own one Dan).
Hey, didn't I provide that info a couple of weeks ago for you?:rolleyes:
I just got around to it this weekend, and the FIL wiring diagram was concrete evidence. I'd totally forgotten your post. :doh:
