Supra Fuel Pump
Reno, NV
So I did the search, but I couldn't find how much pressure the Supra pump is good for and what kind of lph it is capable of. Any ideas? Also, I know that it will fit (with a little work) on the 93+, but will the supra pump also fit the 91-92's?
Thanks,
Jack
Thanks,
Jack
Don't remember the pressure or flow off the top of my head but on a Supra the pump is good to about 600 crank horsepower.
why are you looking at the Supra fuel pump? I put one on because I am SC'd. Not sure if I needed to.
Doing my homework on putting a GM LSx 5.3L/4l60e into an 80. Just checking to see if the Toyota fuel pumps will work. It looks like the Supra pump should handle the job, specs right where they need to be. I just need to confirm that the Supra pump will work in the 91-92 FJ80 tank.
Jack
Doing my homework on putting a GM LSx 5.3L/4l60e into an 80. Just checking to see if the Toyota fuel pumps will work. It looks like the Supra pump should handle the job. I just need to make sure that the Supra will work in the FJ80 tank.
Jack
It works on the 80 tank, mine has been in a year without a problem.
So your question is the 91 tank the same or similar to the 97? Not sure on that one
