Supercharger Throttle Cable Routing
Golden, CO
So, I'm at the step where you relocate the bracket from the charcoal canister to the top of the fuel rail to hold the throttle cable. However, it seems like the bracket isn't really angled right and wants to dig into the cable really bad. Probably not a good thing long term. I'm probably just going to make a different bracket with hardware store parts, but I figured I'd throw it out there to see if anyone has an off the shelf part that works. Or has anyone come up with a better throttle cable routing for the supercharger?
Nope, used what was there. It kinda keeps it in place enough to not dangle around. I didn't see enough of an issue to do anything about it. It's been close to 50k miles and it hadn't moved.
Relocated original has worked for me and others I've helped with installs. Those were done a long long time ago without issue. There's a metal sheath under that plastic outer coating of the throttle cable...
cheers,
george.
I'll look at what I have on mine. Possibly I never even re-used the clamp :) Been a LONG time. Will look tonight.
cheers,
george.
Mine is angled up, but it might work better down. My wire harness is in the way though. I can't really tell from the picture how its supposed to go.
Mine still used the cable support on the side of the vapor cap. Then the cable curves back under the finned intake extension housing, between the engine lifting hook and the intake manifold. Cable is fairly relaxed and does not bind any. Been like that for over 100,000 miles.
Ok, got a chance to snap a pic of mine. Hopefully clear enough to give you an idea how it is mounted etc.
cheers,
george.
Thanks! I wound up grabbing a hose clip from the bottom of an old charcoal canister I had and bending it to fit:
@DARKNESS where you have extended the coolant line (with the inline barb) as per the s/c install manual, I would highly recommend when you are 'in there' next time to just replace the entire hose with a single piece. On my install that barb area leaked (and has for others). The other end of the hose goes to the block in a similar scheme as the PHH (i.e. a hardline 'outlet' on the side of the engine block).
You can see how I extended mine after years of it oozing coolant (even when I cut the original hose a little shorter year by year to get some 'fresh' hose end for the barb to go into).
Just scroll down to find where I talk about going to a single hose piece etc in this writeup ->
Injector Service
cheers,
george.
You know, I thought about that but it never got around to it. Thanks for the tip, I'll do it later. Can it be done without removing the throttle body?
Yeah, it could be done with the upper intake in place, since you have to reach up from below (similar to PHH) anyway. Having the upper off really doesn't buy much in terms of access to an already tight area.
cheers,
george.
