Super easy remote speaker for ham/cb
I am posting this in the 80 area because i feel like it pertains to are mote speaker mount in the 80. I mounted my ham on the back of the center console like a lot of you guys. But i think this pertains to most mounting locations. When mine was mounted the speaker was squash agents the center console making it hard to hear. Probably the same as a in dash mount.
My Yaesu 2900R has a 3.5mm mono jack in the rear for a remote speaker. I went on Amazon and bought a 3.5mm mono cable with a RCA jack on one end. I think it was 3 or 4 feet long and cost about $3. cut off the RCA jack and soldered the wires to the crappy OEM speaker in the dash near the driver. Thats it, remote speaker in the dash.
Hardest part was removing the center console to run wires and dropping the lower dash to get the speaker out. You know that takes all of 5 min. Best part is if i want sound from the ham it self i just reach back and pull the plug out of the head unite.
The RCA type cable is strange. It has a red, whit and shielding wire in it. Who knows why but the speaker liked the red and the shielding hooked up. Also the factory speaker at the factory plug connector uses what i think is a resistor. if you hook it up straight the the speaker and skip the resister it is twice as load, so that is what i did. The speaker is marked 4 ohm and that is what my speaker output calls for.
I am sure other people have already done this but i dint really look.
I did this same thing. I have HAM going to the driver and CB going to the passenger speaker.
I did the same but I wired the dash speakers plus the ceiling mounted things in the back! Sounds great!
Rca cables are wired that way on purpose. And the resistor on the speaker is, I believe, either part of a passive circuit acting as HPF or to match driver sensitivities, or both.
