Super duper mondo velcro from hell....
3M Dual-lock. This is the plastic hook and loop rather than the "fuzzy" stuff. Just make sure the surface is clean. The adhesive backing on it is A LOT stronger than typical 3M double sided tape. I hear the adhesive is a mixture of elf spit, voodoo, spider webs, and the juice of a berry found only in a small region of Nepal.
Of course, that may just be urban legend. Anyway, the stuff sticks.
I think marc311 is refering to this. Check out www.mcmaster.com search hook & loop / self locking mushroom head. They have a extra strong adhesive backed version available. Hope this will help
I love mcmastercarr. When you buy their hook & loop, you have to specify:
-width
-length
-color
-cycle life
-shear strength
-pull apart strength
Couple of possiblities:
pn 96055K48
pn 94985K911
Now, where's that sheep......!
Not gonna read all this...But, did anyone mention to clean the surface prior to sticking?
Use alcohol, or a quick wipe with acetone, (fingenail polish remover). But if you use acetone, go quick and maybe do it a few time, quick....Dont let it linger on the surface cause' acetone will melt plastic within a few seconds.
I used 3M heavy-duty strength found at Ace hardware to attach my Sirius receiver.
It's attached to the carpet high and tight in the passenger footwell against the center column. That thing puts out some heat, but it hasn't been enough in a few months yet to cause the adhesive to lose its grip on the carpet.
