Sunroof rails leaking.
What I am observing is when there is water in the trough that leads to the drains it is seeping under the guide rails and onto my headliner.
Anyone seen this before? Is there a fix that does not include removing the sunroof and disassembling it?
Thanks!
Well I suppose I'll sub this just in case that's what's causing my make out session foggy windows.
Are the drains clean?
If they're clean and are still connected to tray, about the only way it can leak is the sunroof being open....
Even if the weather stripping on glass is questionable, by design, it should wind up in the tray, unless parked at a angle, possibly in flooding rain conditions.
Blower Air on Recirc or Fresh? I know stooooopid, but I still gotta ask.
Sometimes overlooked:
Rain leak into cabin
You may also have a problem with the little plastic dust covers in the sunroof. My rig was leaking from there, and water would run inside the headliner, down the A-pillar, and down onto the footwell on the DS.
My truck leaks too...
Worth checking there while you are at it. The replacement parts are about $12 a piece list, different part numbers appear for different years.
63255 COVER, SLIDING ROOF GUIDE RAIL, RH
63255‑60010 (01/1990 - 10/1995) 1 $12.06
63255‑60011 (11/1995 - 12/1997) 1 $11.47
63256 COVER, SLIDING ROOF GUIDE RAIL, LH
63256‑60010 (01/1990 - 10/1995) 1 $12.06
63256‑60011 (11/1995 - 12/1997) 1 $11.47
So far my rig has been dry all winter on the inside, knock on wood, after so much fun chasing leaks last Winter and Spring.
:cheers:
Steve
@Hornd. Well apparently I'm stupid bc the recirc vs fresh never seemed to matter on any of my other vehicles. Can you fill me in on why his would matter?
Has to be a plugged drain. Get up there with a bottle of water and find out for yourself.
I did this and the drains are working fine, I snaked them with weed eater line and blew them out with compressed air. They actually make a sucking sound when enough water is introduced. When i pour water into the the gutter that feeds the drain the water goes away pretty quick but not before i see some drips come out from the capture nuts and under the rail.(i have pulled down the headliner) I put all new seals on the plastic covers but just to check I took them off and poured water in slow enough that it would not raise to the level of the covers but is am still seeing drips under the pan. I dammed up the pocket that the plastic cover goes over with clay so that no water could get in and then plugged the drain. I then poured a small amount of water in, just enough to create a shallow puddle well below the level of the plastic covers and i still have drips under the pan from the capture nuts and the end of the rail. While doing this I can look down into the rail and see water coming into the rail and filling the recesses. It appears as if the water is getting under the rail itself.
My leak is not pouring in its just enough that when it rains for hours like it does around here my headliner gets wet above the doors. I pulled down the headliner and when its raining there is is just a drip, drip, drip.
I have the make out foggy widows also, there was actually water running down the inside of my windshield last night when it froze and I was defrosting.
Im in western WA too.
I found an economical solution to my sunroof leak problem... here's the pictures... I just lined the rim of my sunroof with a thick tape (could be a rubber tape with adhesive or foam tape or double-sided tape)... And ever-since, I had no leaks coming from my sunroof anymore.
My LC Moonroof 002
My LC Moonroof 001
Maybe this could help you, too..
My LC Moonroof 002
My LC Moonroof 001
That looks like 3M double back molding tape with the protective plastic left on. How long does the plastic stay with the tape? Do you open your sunroof or just leave it closed?
