Sunny the 1979
Took the wheels off and inspected. Thanks to @Fireman ans @wngrog for some advice. Appears to be missing the anti rattle clips. The brakes are also dragging/running as you can see in the video/pictures.
Any other thoughts or potential fixes?
Brakes Video
Brakes Video
the W clips as i call them will NOT cause the dragging your experiencing
ONLY 1 or more of the 4 pistons being seized from age and time will cause this symptom .........
i would also inspect your master cylinder closely for good measure , i bet there is a external leak , pull it away from the booster with the lines STILL attached
remove one caliper at a time ONLY , use channle locks and gentally apply slow but firm force , the 2 pistons on one side should both slide bak in the caliper a bit
STOP !
then repeat the other 2 pistons
DO NOT over press back in or the opposing side 2 pistons will / can pop out
then you will need new calipers for sure
repeat on the other vehicle side after re-install of the current test caliper
if even one of the 8 caliper pistons is sized in any way or very hard to set back inside the caliper
also look for the rubber boots being torn water infiltration can occur here
then i always replace both calipers with OEM Toyota re manufactured parts genuine ones
good value price point for what you get
all new mounting hard ware including 4 caliper mounting bolts too
slide pins
ships
pads
and yes anti rattle clips .....
sounds like alot , but eazy peezy job ...... :cool:
i always use full synthetic caliper lube on all moving parts pins shims etc ...........
back sides of wheels too to prevent future wheels to HUB seizing as well
you trusty chassis body FSM OEM manual goes over brake sin good detail refer to it at all times
Also, I'm having a hell of a time finding an OEM driver side caliper. Does anyone have ANY insight on when these won't be back ordered or where on earth I can find one that's available?
Proven aftermarket options?
Really holding me back from getting Sunny back on the road. Help is appreciated!
Toyota 4x4 front brakes of that era are surprisingly interchangeable. I would consider alternate factory options before looking aftermarket. Late 80s IFS calipers will bolt up and offer a slight upgrade due to larger pistons but won’t fit with all wheels without some modification (grinding the caliper body). FJ60 & 62 calipers will also interchange.
It looks like OEM rebuild kits are still available for the stock calipers: 04479-30031, pistons as well 47731-30020 and 47732-30010, rebuilding them isn’t very difficult.
The baseline/upgrade train continues...
Sniper
All brakes, lines, rotors
Radiator and hoses
Water pump
Thermostat
Drivers lean correction
almost refreshed and back on the road.
Goode’s Offroad near Dallas is performing the work and the communication has been great so far. I’ll update on quality after.
last replaced in 99 😳
47730-60021-84​
Caliper Remanufactured​
$117.82​
1​
$117.82​
47750-60021-84​
$117.82​
1​
$117.82​
Order them online from your local dealer for your best price. When they inform you they’re ready for pick up, take your old ones with you for the core reimbursement and your done.
Ordered. Thanks again!
Well Sunny is back after a long stint to the mechanic and it feels good! Next up, drive the beast so Sniper can learn. Long list of baseline and extra goodies...we’ll see how it goes.
Sniper
All new brakes, lines, master
All fluids flushed and replaced
Clutch master and slave
Water pump
Radiator
Assorted hoses
Thermostat
Knuckle rebuild
Cruiser lean addressed
Etc!
Looks good. You might want to keep all the parts from the EFI swap - they are valuable and you never know how emission testing will go in the future (with the big push to get rid of gas vehicles...)
Have all of them stored away in a box!
