Also while climbing a hill I had to use my winch and noticed gas pouring out of the filler door. You can see it near the end of this video (sorry so long...)
So it’s not the seal on the gas cap?I think others have had the same issue when climbing to higher elevations. If I remember correctly, you’ll want to replace your charcoal canister. It isn’t letting the gas tank vent correctly, thus forcing it out the fuel filler neck. Search around and find the thread... I’m sure it’s on here somewhere.
Could be, but you more than likely have a problem with internal pressures if it was being forced out. Like others have said, the VC120 is a cheap/easy no-brainer 'mod' to relieve tank pressure. The old canisters get clogged over time and can contribute to the dreaded burst gas tank which many have experienced. Replace it and do the hoses and clamps at the same time - should be less than $60.So it’s not the seal on the gas cap?
Thanks for the part number and advice!Replaced my charcoal canister recently with the Autozone VC120, works great. Had it vented to the atmosphere for a while prior to that but got tired of the gas smell.
When you open the gas cap does it release pressure? Could be a combo of a bad gas cap and excessive pressure in the tank.
