Sun Visors
The difference is mostly in the mounting arm. Later model does not stand out away as much as the earlier models which needed to clear the motor and cables.
I don't recall my old 1/79 blades being any bigger than my earlier blades bit it has been awhile since I had the 79.
I have two 78 windshields on two of mine and a 74 on another. The blades are all the same size. A bigger blade would be nice.
I guess my main question is whether the windshield mount holes match up?
On the ones I have owned. 9/69 thru 1/79. All the mounting holes and the mounting brackets were the same. The only difference being the arm.
Maybe someone could measure the holes on a newer arm. It would be nice to have a better visor that just bolts up.
Anyone know if the 79+ sun visors fit earlier year FJ40’s, particularly a ‘77? Looking to get a new OEM set and noticed the blade on the later years is bigger which would be nice.
I have the newer sun visors (74320-90303 & 74310-90303) in my '77. The mounting holes line up correctly.
Thanks GA. I'm not the tallest guy on the basketball team so having sun visors that reach a little lower on the windshield will be welcomed. I'm ordering an OEM set from Cruiser Corp.
Click here: -> 74320-90303 <-
Click here: -> 74310-90303 <-
I have a '67 and wonder how these 69+ units will fit with the wiper motors?
I have visors in my 9/64 FJ45LP-B. Using the same visors my 68, 70, 73 and 76. The 69+ is only listed because Toyota dropped everything from the parts system prior to 3/69 many years ago. Bolt pattern is the same from when the visors started during the sixties until the end of production of the 40 series.
I went to an upholstery supply house and bought some steel rods that were the same OD as the originals and made my own sunvisors. I made them much longer so they barely clear the rear-view mirror, Used the original swivels and got some hard 1/2" padding for the inside "guts" of the visors. In retrospect, some hardboard would probably last longer. Took a few tack welds to hold it all together. Sewed up some new gray vinyl covers for them. Looks and works great.
I bought sun visors from Specter Off-Road last week for my 1970. It looks like they have what you want in stock.
