Sumotoy Zero-Boost turbo Wheeling Mod
Chicago
This modification is for those running turbo trucks offroad, specifically looking to run zero-boost turbocharger/s during low gear crawling. Here is how to run zero boost on a turbocharged truck.
SUMOTOY ZERO-BOOST TURBO (SZ-BT) WHEELING MOD - Install/ed 1 or 2 standard bypass valves (depending on size of turbo/s) in the intake plumbing post turbocharger. Pull the vacuum line from bypass valve to the manifold and put in a 1 way vacuum ck valve T'd to a vacuum tank. At idle the turbo bypass valves will open, and stay open = no boost. Any attempt at intake manifold boost ramp up will close the vacuum ck valve, the bypass valves stay open = no boost under engine load. 8 bucks for a good vacuum ck valve and common vacuum tank from anycar/anyyard USA? No changes, no addon's - you can use existing turbo bypass valve/s, or install them specifically for zero-boost wheeling.
Using a closed loop Bypass Valve (excess boost recirculated to turbo intake - post MAF/pre turbo), all measured intake air will result in proper non-boosted fueling. After low-gear zero boost wheeling, remove vacuum ck valve and attach bypass valve line directly to intake manifold = done. Same modification works with any turbo: size/number/map(s) = no load/no boost freewheeling turbo/s at any rpm in any gear.
HTH
Scott J
94 FZJ80 Supercharged
Devil's Advocate post here......
Why would one want to spend several thousand dollars on a forced-induction system and then promptly neuter it?
Dan
Good question! Dusty has indicated in a different thread that turbo ramp-up during low gear rock-crawling can cause loss of control during delicate rock-surgery. This mod will address that concern by neutering the boost all-together. That said, I have done rock-crawling for many years in my 4Runner turbo, and have never experienced this loss of control in low gears.
Dusty has also shared that this is a common issue on the Pirate boards with boosted trucks. Without commenting on the reason for the neuter in post 1, just explaining the procedure to accomplish the task?
Cheers
Scott J
'K, I guess I can buy that.
It must be something to do with the way a turbo works versus the way a supercharger works. I have never had any "overpowering" issues with my S/C. The linear boost properties of a blower perhaps?
It must be something to do with the way a turbo works versus the way a super charger works. I have never had any "overpowering" issues with my S/C. The linear boost properties of a blower perhaps?
I don't buy it, I never noticed it in my 4Runner turbo or the SC in my 80. I suppose with a big enough turbo, ramp up can be significant. With the SC, I suspect it's a combination of linear boost properties and zero lag properties of a Supercharger. Thank goodness the fix for the turbo boys appears cheap and simple. That said, those with an SC application sharing the "unnerving" experience, the fix follows the same logic, the ck valve is just installed at the stock M90 SC bypass valve = All SC boost is recirculated internally.
Scott J
I think if you read what Dusty wrote it was more of a concern of generating excessive heat do to the lack of air flow from crawling off road.
Personally I don't see a need for more power in low range than what a NA engine provides. I'd like to incorporate this with a valve tied into the Low range selector to automatically kill the turbo when selected.
I disagree to a degree Rick.
My wife's truck, with stock gears, 35's and a plain motor requires a lot of two-foot driving to negotiate obsticles. Lots of power-braking to climb stuff but not over-shoot when you pop up.
Probably a terrific thing for an improperly sized and setup turbo. Totally not necessary nor wanted with a turbo sized and setup properly. With minimal practice, the turbo adds whatever you want and nothing that you don't during wheeling. It is all completely easily controlled by application of accelerator. I'm no where near as graceful giving the rig gas as some really savvy wheelers here (I'm getting better bit by bit though!) but I can get through things where I want no more power just fine and I can get through things where I want much more power just fine. I think this is another incorrect assumption that turbos must lag, that turbos must boost instantly beyond control, etc. Just not true with the proper turbo. You also wouldn't want to take the turbo "out of the picture" as soon as low range is selected, that would be a big waste of versatility. Anyway my .02$. :cheers:
I didn't read that at all, I primarily focused on his "unnerving" claims with regard to control....
DUSTY said:
... no its a gearing problem. on a steep climb, even in first low, one is forced to load up the torgue converter to continue moving. this requires rpms. once they get to 2300 rpms in my truck I start boosting. this can be unnerving when control is is needed. Rocks like control-thus it is called "rockcrawling".
lower gears allow one to keep moving without loading the torque converter.
Scott another issue with turbos and wheeling is controlling the heat....
I think low speed crawling 'heat control' is not a turbo selection solution... Thankfully, this simple mod addresses both concerns...
I think the concept of "too much power" during low speed wheeling is BS myself, and it's what you are used to. You drive a turbo/SC enough, boost is no surprise, and I could care less what gear you are in and what you are doing. I've rock-crawled and low gear wheeled with a turbo 4R for 11 years, can't relate to the problem. I run turbo awd (even my SC 80) at Steamboat Ice Track for 15 years, where sudden hits of full boost at much higher speeds could prove either "unnerving" or "predictable", and always found the latter.
This appears to be an easy fix for any size turbo. My *reason* for posting up the mod, is to *neuter any possible claim* that a turbo choice could be 'good' or 'bad' with regard to success/control in low speed wheeling. I also think that very concept is complete BS, but again, for 8 bucks, problem solved.
Add bling to the mod? Use an inexpensive electro/pneumatic T from Grainger/Parker that could make this a simple switch on the dash to change the vacuum routing to the bypass valve. But, I digress...
I also share the possible irony of any thought that rock crawling is delicate, especially with a large footprint 80. Surgery with an ax comes to mind?
Scott J
Many times fixed, never neutered
I don't have stock gears Dan. And what you describe is a gearing issue isn't it?
Effective gear ratio can affect engine load for a given "obstacle". So can tire design, skid plates hung up, approach angle, and a myriad of other issues involved in offroading. A turbo will *help* by increasing Trg (Torque Ring Gear) for any given rpm. A bigger turbo will increase that torque later, a smaller turbo will increase that torque sooner, and no turbo will require more rpm to attain the same Trg.
I claim crawling with a turbo or supercharger has very little to do with gearing.
Scott J
Scott J
I was speaking to Dan's specific scenario.
the only thing i can add to this thread is that i also have stock gearing and 35's. With my rig in low range, i have yet to have a power or control issue climbing obstacles. I do sometimes want just slightly lower gears when going down an obstacle. But it's really not bad at all IMHO.
... And by definition, the turbo is out of the picture coming down an obstacle anyhow. More potential available Trg (torque at ring gear) by applying boost instead of Teng via engine rpms, actually seems like *more* control to me, not less, especially with a torque converter... Regardless of the final drive ratio or gear multiplier chosen.
Wonder how Unimog, Pinguaers and P4's handle turbo boost crawling with much lower gear ratios than an 80, esp with no torque converter to help regulate Trg.
Happy to post how to eliminate boost from a turbo motor, a rather amusing first design concept for me in 25 years of turbo tweeks.
Scott J
OK , so a year back or so we had a member traveling to Mexico and central america w/ a SC'd truck and wanted to know if he could somehow "turn off" the blower when he could not find high octane gas to prevent predetination.
Would this trick here, applied to the SC, work for this scenario? (excuse my SC operations ignorance :D)
or will long term internal recirculation negatively affect components?
Absolutely works for the SC, see post 5. And that's a scenario I'd rather see the zero-boost mods address, it makes a lot more sense. Long term recirculation has no negative effect on a supercharger or a turbocharger, you could install a supercharger and never be in boost for 50,000 miles. If anything, no load increases the life of a supercharger or turbo.
Scott J
it's the gear ratios. low enough ratios reduces engine loads to a point where boost is minimized.
I think that's oversimplified BS. If you get the ratios low enough, you don't have to add gas ever. That's not real life, the go-pedal dictates that Teng is a variable always. And defines that *every* other wheeling gearing scenario has nothing to do with boost. Boost just increases available torque at the ring gear for a given gear ratio and engine rpm. Any crawling "comparison" would require an infinite matrix of conditions impossible to replicate.
This is absolutely the worst way to get your head around this mod. If no boost is your desire while wheeling, it can be done simply. I see no need for it whatsoever, and no condition where no-boost would be a factor to 'better' wheeling. In fact I claim the exact opposite being more true. Let's try some math on a set of wheels
Teng (- Driveline loss) x Tansfer case Drive ratio = Trg
Trg x axle final drive/2 = Twhl (Torque Wheel)
To increase Trg, you can increase the TransferFD or increase Teng. The argument you appear to make seems to center around the claim that increasing TcFD has some comparative inherent benefit. Put a N/A 80 in low range (constant) and the Turbo/SC truck in low range, the wheel torque required to go over a given rock could care less how Trg is applied.
This is the first I've heard of a claim that Trg application by changing Teng variables nets any advantage or gain. If Teng output required to get over the rock is 275lb/ft, what does it matter if that is at 2500rpm normally aspirated, or 1750rpm under boost load?
Scott J
Just to comment on over running, I can relate.
Years ago I recall driving a late 80s Chrysler Labarron Turbo. That car had such bad turbo lag that you could count to 4 or 5 before it would build boost. The other, rather scary side of it, was when you took your foot off the gas once you got the boost, it literally kept accelerating for 1-2 seconds. I assume with proper turbo sizing on newer cars this doesn't occur. I know I haven't felt it on any newer turbo car I have driven (Friends' Audis).
