SOLD Sumo Gears Transfer Case Rebuild Kit - Fits 8/1992-1/98 FZJ80/LX450 with original HF2AV Transfer Case
Status
Not open for further replies.
White Sheep
Darren
Okinawa, Japan
Bought this rebuild kit months back. Turns out I didn't need it.
Currently out of stock at Cruiser Outfitters. Asking $450 $400 shipped (in the continental US).
Listing from Cruiser Outfitters:
High Quality Japanese T-Case Rebuild Kits.
Includes:
1 x Plug O-Ring
1 x Shift Shaft Lever Seal
1 x Transmission to T-Case Seal
1 x Front Output Flange Seal
1 x Rear Output Flange Seal
1 x Form-In-Place-Gasket/Silicone
2 x Drain & Fill Plug Gaskets
1 x Input Shaft Rear Sealed Roller Bearing
1 x Front Output Shaft Sealed Roller Bearing
1 x Input Shaft Front Sealed Roller Bearing
1 x Front Output Shaft Needle Bearing
1 x Rear Output Roller Bearing
1 x Idler Low Gear Cage Bearing
2 x Front Output Needle Cage Bearing Half
1 x Idler Rear (Tapered Bearing/Race)
1 x Ider Front (Tapered Bearing/Race)
1 x Center Diff Front (Tapered Bearing/Race)
1 x Center Diff Rear (Tapered Bearing/Race)
1 x PTO Side Cover Gasket (Not used on US Spec Case)
Kit Does Not Include: (Inspect And Reuse)
Output Shafts
Idler Shafts
Gears
Collars
Forks
Linkage Components
Let me see if this will work in my 2000 t case.
Which part? Maybe I can overcome that.
Sorry I don't know. I have no experience with a 2000. I just know the 2000 is different than the 93-97
Free bump - thought I needed but won't work
Status
