I am a newbie and I need some help. I have a 97 80 (140,000 miles)which seems to have suddenly developed an overheating issue. My wife took it out for a ten mile drive in hot weather, and the check engine light came on almost immediately. I took it for a drive and the temp needle rapidly climbed, within a few hundred yards, into the red. I let it cool off then checked it out a bit: the fluid in the coolant tank is at the full line, there was no coolant visible inside the radiator (the top of the fins was dry), the fan can be turned (with some viscous resistance) with the engine off, and spins when the engine is running. I started the engine and felt the hose going from the engine to the top of the radiator. It had no pressure at all until the temp gauge was about at the half way point. Then there was pressure but it didn't seem like there was much or any flow through the hose. I shut it down before it got hotter than half way.
The only indication of any problem before this incident was the AC occasionally shutting off on uphill stretches..
The truck is stored a few hours drive from where I live so I'd like to be able to bring the parts I need and fix it if I can figure out the likely cause.
I have lots of questions: Is there any potential for damage from driving a few miles in an overheated condition? Is there an idiot light for overheating? Would overheating have triggered the check engine light?
Any help would be much appreciated!
