sub tank system Q's
I have read what I can find in the archives on sub tank systems, but wanted to post up some specific questions.
FIRST If I was going to give directions to an auto dismantler to ensure I could get all available components, can somebody post up pic's or diagrams that show the OEM locations of the transfer pump, and the ecu unit?
Any other components present on a factory OEM system that would be good to get?
SECOND Is there a good reverence thread to use the sea mail system out of AU, that I can use to help navigate the system for the first time ?
Elmariachi has a thread that has required parts list. Ihttps://forum.ih8mud.com/80-series-tech/213266-oem-subtank-retrofit-install-project-pics.htm
lt has pics of everything you need.
Australia Post has sea mail details on their website, including max dimensions of packages and their max. weights.
I will check Elmariach's thread again, but I don't necessarily want to know what the part looks like, I want to see where on the frame/body the part is installed by the factory, so I can find it on the donor vehicle.
Search "subtank install" under 80 Series Tech and will yield a lot of threads including this one:
https://forum.ih8mud.com/80-series-tech/149293-sub-tank-install-questions.html
Check picture on post #14 and #36, there you will see the transfer fuel pump installed in the rig.
