SUA v/s SOA
fyresq said:
- First, a HUGE percentage of 4 wheel drives are SOA - GM, newer jeep, ford, IH, etc. If all 4x rigs started as SUA then I'd never go SOA. My chevy is factory SOA, does that mean it's unsafe and the engineer's that designed it are stupid?
Apples to oranges. Not all vehicles are created the same, which is true of their suspension design as well. (And I do think GM, jeep, ford engineers are stupid. ;))
As for the debate, Toyota did their homework quite well in designing the factory suspension on the 40/45/55 series. If you're going to mess with it in any way make sure you do your homework as well. If you're not confident in your engineering skills then let someone else take it on.
I never really liked SOA, especially on the street, but after driving Andre's truck I changed my mind after he dialed in his springs. But, like others said, it all boils down to what your use is. My use, for what I currently do with my truck, does not require a SOA.
If you're not going to go off pavement much then just keep it stock as a rock...it starts good enough as it is. Lift spring ride holds nothing to my SOA in relation to comfort. Also the SOA is a little tippier than lift springs...because lift springs are STIFF!
Are you planning on crawling over giant rocks?
Are you going to need (insert large number here) inches of articulation per wheel so you don't tri-pod?
Are you mostly street driving this?
Does it need to appear low enough not to get constantly bugged by police?
If you answered no to 1 and 2, although yes to 3 and 4...you probably don't need the SOA and should stick to keeping it low. If you answered yes to 1 and to but no to 3 and 4 then get the SOA DONE and post pictures as you go.
My $.02 and I'm sticking to it this time.
