STUPID LIGHTS!!! AARGGH-help
hey guys, i have a 76 FJ55.
i only have one brake light, right rear
only one rear blinker, right rear
flashers, all 4 lights work
all tail lights work..
so basically
the driver rear brake light and blinker dont work, but the flashers all work.....
figure that out?
Pin_Head said:
The turn signal problem is probably a bad turn switch, but it could also be a bad connection after the switch. The brake light is probably a bad connection or bad bulb somewhere after the stop switch.
the switch did work about a week ago.. just didnt blink the lights.
-could be the problem, the front blinker works, just no rear
the bulbs are all good, but i will double check....
the blinker has 3 wires, i replaced (or tired, rather) the factory blinker with a generic one, but no luck
If it doesn't blink, there is a high resistance connection somewhere. The bad connection has to be between the turn switch and the hazard switch. Could be a bad contact in the switch too. Either way, you will be digging in.
You may also want to clean the area where you insert the bulbs. make sure you have the correct bulb in it as well. When I first bought my fj40 the PO installed the wrong bulb on the front and so it would not blink unless the engine was running.
