well the first time out wheeling the 80 i broke a 12mm bolt that was holding on the sway bar drop bracket
This is just a heads up to who ever is using this type of Slee drop bracket. Now this is not a rant on Slee's bracket since this is a bolt on part not his fault that this bolt failed just offering my solution to the problem or a preventive maintenance item in some one else case.
so i drilled out the two 8-1.25 holes and tap them out to 10-1.25 used a 14mm head bolt from my pile on mini truck bolts...fix works great, I trust this a lot more them those 12mm
