Stumped, engine fires then immediately dies
Bozeman, MT
Howdy folks-
Well, I just got into my cruiser to fire it up and it isn't acting right. I know all I need is spark, fuel, and air... so here is what I know.
Issue started a few days ago, then went away. It happened once before tonight and then fired right up, tonight I couldn't get it to go. This is literally the first time ever it didn't start on the first or second try.
My fuel level in the sight glass on the carb is half way. Good.
I have spark at all the plugs, verified with inductive timing light. Good.
The truck just starts and dies, choke out, pedal to the floor once, crank, crank, Varooom! dead.
Same with the choke out or in.
If I try to crank, crank, and tap the gas, same thing.
Waited for a long time to make sure we didn't flood the carb, dead.
I can see a small leak on the front of the carb where the throttle linkage "rod" runs through the base of the carb and is attached on the front outside face of the carb. Maybe one little drop per starting attempt... not good, maybe a vacuume leak? Sprayed carb cleaner on the leak while firing, no difference.
The interior or "choke" side of the carb looks pretty dirty.
I can't see fuel getting sprayed into the throat of the carb when starting and pumping the gas pedal... shouldn't I be able to see it spray?
All vacuum lines are connected, verified.
Here is what I still need to check:
That the fuel is coming into the carb, and for a dirty fuel filter.
FWIW, I installed a radiator today but it was a simple swap.
Kinda at a loss here, any thoughts are much appreciated.
Thanks in advance.
Rezarf <><
You might want to put a voltmeter on the coil(+) and monitor voltage during cranking/after you release the ignition key.
After cranking voltage may be < 12V, depending on whether your running points...
I have experienced similar symptoms which where caused by a faulty ignition switch.
manny
manny
Thanks-
I am running an electronic ignition from a fj60. Would that make a difference? What would I be looking for, a drop in voltage?
Thanks
Rezarf <><
I have an electronic ignition on my '74.Did the same thing. I found out that the
ignition switch was bad.Put in a new switch and fired right up!
How long since you cleaned out the carb last? You say that nothing sprays out the accel pump discharge nozzle when you pump the pedal. That's not a good sign.
Get enough dirt in there you can clog the primary jet as well. Mark W. had a cool photo in TT a year or so back with a nice little piece of seed stuck in the jet.
Just a thought.
GL
Mark A.
You definitely should see fuel spraying into the carb. I'd guess accelerator pump first.
Thanks-
Going to try some differnt things and then I will post up with what i find.
TIA-
Rezarf <><
I don't know if you have a ballast resister with the electronic ignition. I think its there to prevent points from burning up so you may not but for those that do, mine went out recently and it did the same thing. It would fire when the key was on start then die when in the on position. On start the resister is bypassed for maxum power. I put in a small piece of wire to bypass the resister to get home and replaced the unit when I could. Anyway, this may not help you but it may for others.
Well,
Tried some different things with no results.
Then I checked all the wires at the coil/ignitor, since I am running the electronic ignition from a fj60. Jiggle them all, and all "seemed" good, went in and the rig fired right up and ran great.
I am going to clean all the connections and check the ignitor/coil for correct opperation.
thanks!
Rezarf <><
Cool, good job. Is the igniter for the electronic dizzy similar to a resister for points? I would really like to convert over to a later model dizzy but I am not really familiar with them.
Thanks
