Stumped again
SoCal
My project has me stumped again. The exhaust mainifold on this 74 FJ40 is totally FUBARRED. Cracked in two places. Adios. Gonna just buy headers. But this is where I'm puzzled. How is the the intake manifold effectively bolted to the head if the OEM exhaust manifold is missing? It looks like they're designed to be bolted to the head as a "unit."
Vic
They are"like a unit" but headers wont change anything.
That's too bad. I was gonna ask you if you wanted to sell that stock manifold, or use it as part trade on a header.
Anyways, the headers are designed with the same 'ears' that the stock exhaust manifold had, effectively half-circles needed to complete the half circle made by the intake manifold.
Do a good thread search on headers and you will learn that not all headers are the same in terms of fit, quality, and long term durability. I of course am biased in favor of the Tri-Y headers that I offer, because I hate dealing with warranty returns. Others have also offered their .02 on their purchases, which may have also been influenced by $$, or, more precisely, lack thereof.
I am not an experienced guy in terms of headers. I bought a 2-piece SOR from IDave and I've been happy with it. Two things I can say is that the flange on the header I have is the same thickness as the intake, so no "split" washers. The other is that I know the one I have will NOT work with a factory PTO winch, which is why IDave sold it.
With any header it is very important to retorque several times and use a good gasket or gaskets, depending on who you listen to. I use two on mine and retorqued about 5 times and have no leaks. If you live in a cold climate, you might want to consider a fluid heat riser. Easy to make and as far as i'm concerned, they help with cold weather starts and warm ups. I also made a "warm air" intake for mine that fits the 2F aircleaner.
.02
Ed
I certainly don't have much expertise in this, but I know the 40 I'm working on came with a header on it, and it all looked like one unit before I took it apart. It will go back on after it is blasted and cleaned up. I can speak from experience on the re-torquing of manifolds in general and Ed is correct, re-torque, re-torque, and re-torque. It isn't hard it is fast and it can save you a lot of headaches! Please don't ask me how I know.
Thanks for the info.
Mark, we'll be talking soon relative to the headers as I'm about an hour away from y'all.
I used to run headers when I had the stock engine, had to cut washers in half, glue in place, not sure if headers have evolved since then since this was 10 years ago, anyhow, I would look into having the header and intake milled to the exact same thickness as possible and as well use some type of locking nut, I got some nuts from the toyota dealer many years ago, not sure if they were stock or ?, but they were oblong and molded to fit the stud, thus preventing them from backing off, worked well.
Noah
