Stuck Warn Hub
Bay Area, CA
Hey folks,
I have a 1970 FJ40 which spent a couple hundred thousand miles on a ranch in Wyoming with little in the way of maintenance. One of the Warn hubs refuses to come off. I can break the hub free but the spring loaded plate refuses to come out of the housing. I suppose its stuck to whatever it rides against. If I pull harder on it I will risk stretching or breaking the springs. I have soaked in PB blaster extensively to no avail. Anyone ever have this problem? Any suggestions?
Thanks in advance
Are you trying to remove the selector knob or the lockout body (part that bolts to the hub) ?
If lockout body, you've got to remove the circlip.
I would check and see if there is a rebuild kit that includes a spring for that warn hub and if so buy it and do what you have to in order to get the old one out.
Welcome to MUD Bags.
That is a problem that is common to that particular hub, and yes, you will end up stretching the springs into uselessness.
I gave up patience on that hub YEARS ago and run an earlier Warn hub that is much stronger and has NO SPRINGS!
The good news is that there are so many people on this board that are doing or already have done a disc brake conversion, that you shouldn't have much trouble getting one or two or even a dozen of those Warn hubs for not much more than the cost of shipping if you post up in the Wanted section.
Good luck.
