Stuck on Center Diff
Hopefully last update:
Took off the actuator. Cleaned the outer electrical connections (I did not open it up). Moved the locking fork away from the third member with my finger. Buttoned it up and it is OK.
I will put the front driveshaft back on tomorrow and drive with the center locked for now.
One observation: when on the truck, the lower long stud holding the actuator to the third member will not come all the way out because it hits the rear tie rod. The FSM says to align the long arc shaped hole with the knock pin and rotate the actuator counter clockwise (see step g from the post just before this one). The lower stud cannot then go on if you do this, so I think this step is meant for when the entire front axle is off the truck so the tie rod is not in the way.
I did not power up the unit through the electrical connector on the actuator to try to fully lock it that way. Many are saying to use a 9 volt battery to do this. The FSM says to use a 1.5 volt battery. Which is right?
I may try this again next spring when I have more time but I need to know if there is a way to properly lock the front axle without using the actuator (i.e. as with a screwdriver and brute force?).
I dont really think its good to drive around on pavement for a period of time with the front locked.....?
scrowley: The front is now free, only the center is locked because I took out the front drive shaft. You are right; can't drive well on pavement with the front locked.
a- the stud isn't supposed to come out; the nut is supposed to come off it.
b- the truck uses a 12 volt battery, I doubt 1.5 volts will do much.
True but the FSM shows the install without studs so the rotation of the actuator can take place using the knock pin as a guide otherwise the studs get in the way. So I conclude the FSM is written for actuator work with the third member removed.
What?
Why would you keep the center locked?
I think he means he'll drive with it locked now, as in with the DS dropped, not after he replaces it.
That's right Ebag333, when the DS is in, the CDL will be off unless I really want to burn money.
@Jacques Villeneuve this happened to me today. How did it resolve for you? Well, i hope!
(I wouldnt bring a thread this old back from the dead but i can see OP is online at the moment)
For a little more info, the front locker is stuck on (same symptoms you described with bad steering and tire scuffing) and the light did not turn solid when it locked.
I was on loose dirt and, having just rebuilt the front locker, wanted to see if it would engage. I also replaced the locker position sensor. The sensor indicates the locker is off but the truck suggested otherwise.
I jacked up the front end and put the transfer case in neutral. Both front tires spin together in the same direction. I will try it with the 9v battery today and report back. Im mostly wondering if this caused any permanent damage and whether you were able to get the locker working properly again.
Worked out fine.
Actuator motor was working fine per 9v test. Armature spring mechanism was fine BUT the pass through from armature to the gear on the outside had frozen up. Separated the armature from the housing. Greased the housing with MP grease and its good to go.
No affect on the diff that i can tell at this time.
