Stuck on Center Diff
S. Ontario
97 Lx450 - dashboard center diff lock switch
- tried exercising on gravel - Light turned on - no problem
- tried the front and rear electric locks (std. Toyota electric lockers) but the lights just flashed so I truned them off and then turned off the center and the lights went out.
Problem is it drove on pavement like it was locked (hard to turn - lots of clicking) = only went about 100 feet.
I parked it at a nearby parking lot and took my wife's LX470.
Should I:
a) take out the front drive shaft on the spot and lock the center diff again and drive away
or
b) take out the rear drive shaft on the spot and lock the center diff again and drive away
or
c) have it towed to a 4x4 mechanic and have him diagnose it
or
Thanks in advance.
Is there a place you can get it onto a non pavement surface? How long did this scenario take, 5 minutes or an hour? If the lights are off, the lockers shouldn't be engaged.
Try driving in reverse. Also try driving in circles (left and right, forward and back). If you do it on a softer surface it works better too.
To clarify, the diff lights are off and the CDL light is on? Or are all three off? If all three are off you should be unlocked, and it'd indicate a problem with the VC. If the CDL light is on, you just need to get the bind to release.
Drove in circles. Took 5 minutes. Lights went out. Drove on pavement like it was locked (bad steering).
Any other ideas? Thanks.
The light is actually activated by the CDL physically locking or unlocking. If the CDL light is off, then the CDL should be unlocked.
Do you have a CDL button? You can use your emergency flasher switch in a pinch if you don't have one.
With the key in the ON position (but the engine off), hit the CDL button and see if you hear the CDL cycling. There should be two clicks, and the light should go from dark to flashing to on (may skip flashing). If you can cycle the CDL on/off no problem, then your CDL isn't your problem. You can also get under the truck (with engine off, tires blocked, etc etc etc) and have an assistant cycle the button while you listen to the CDL itself to see if it engages/disengages.
Sounds like your VC has seized, which might be the first case I've heard of where someone actually knows pretty much the exact moment that the VC welded itself together. Are you running the same tires and same PSI on all four tires? When playing around did you put the vehicle in situations where lots of tire slipping happened with the CDL unlocked (such as trying to spin a tire on gravel)?
Will try to hear the CDL switch (yes, I did the 7 pin mod with the CDL switch on the dashboard).
Just the center was locked (confirmed by the light which has now gone off as expected) - the rear and front were not (lights just blinked).
I have noticed in the past that when the light goes out, the system get unlocked but still drove like it was locked a few feet and then I would hear a click and the system would fully unlock. This time it stayed locked (with all lights out).
I am going to pull the rear drive shaft now and see what gives (I will lock the center again).
btw Tires are good. I may be able to back up into where the gravel pad is 9could not before because of the binding in the drivetrain).
Thanks.
More EBag333's question: No, before noticing any problem, I was on loose gravel and locked the center diff and the light turn on, then I tried the front and rear lockers but neither light stayed on (just blinked) so I turned off the locker lights (the "magic" dial) and also the center diff lock light (CDL switch). i did not do much if any wheel spinning locked or unlocked.
UPDATE: Took off the rear driveshaft. Locked the center diff but the truck drove the same way (binding). Tried forward and reverse while turning left and rightt on loose soil and it did not unlock.
Tomorrow I will put the rear driveshaft back on and take off the front driveshaft and see what happens.
If it is the front diff locked up, will it drive normally once the front driveshaft is off?
If it is the viscous coupler (VC), will driving it with the front or rear driveshaft off make any difference to the way it drives now?
Anyone have a link to removing the viscous coupler ?
Thanks.
Will jack up the rear (one wheel at a time) and turn the tire to see if it rotates freely. If not, would you say the rear is locked without the light on. I have to so as to get the driveshaft scribe mark I put on it in the parking lot to line up with the driveshaft. I hope no one "plays"with the truck in the parking lot tonight!
If your problem was either the VC or the center diff lock, removing the rear (or front) driveshaft would have relieved it immediately.
So Spike; I did remove the rear driveshaft and the problem remains. So you are saying that doing so would have made the truck drive normally if the problem were a center diff lock or viscous coupler problem. Since this did not help, what else could it be? A broken birf? What would be those symptoms (never broke a birf).
I'm going to take a guess and say that your rear locker might have engaged that one shot and then got stuck. If your indicator switch in the rear diff is not working the light would also just blink. Maybe the actuator itself stuck in the locked position. Mine did. Try using a 9v battery to cycle the rear diff lock motor. The front is probably the same. Try lightly taping the case of the motors. Mine had the same symptoms. The front loosened up by taping motor and cycling with 9v battery. The rear got stuck locked and I had to take the actuator apart in the locked position, disassembled, greased, assembled, installed and now all my lockers work. I hope this is relavant to your symptoms
Thanks scrowley.
I intend to take both drive shafts off and see if the pair of front/rear wheels move in the same direction (locked) or in the opposite direction (not locked).
If neither of them is locked (hopefully), I will look into the Viscous Coupler by attaching one of the drive shafts and see if the wheels turn when both the transmission and transfer case are both in neutral. If there is no movement then it has to be the viscous coupler since the center diff lock light works on demand (on/off).
If either of the front or rear is locked then I will do what you did and remove the locker, clean and lube it, cycle it with 9V battery and then put it back on and hope for the best.
Yep. I'd look at the lockers first, lift a tire and try to spin it.
UPDATE: Got the truck towed home and will attempt to fix in my garage. It looks very much like the front differential is locked with the indicator light off. I took out the front driveshaft and raised the front off the ground at the parking lot the truck was stuck in - both wheels turned together in the same direction - if it was unlocked they would have turned in opposite directions.
The viscous coupler seems OK because when either the front or rear driveshafts were in the the tranny and transfer case were both in neutral and the center not locked and both wheels at one end or the other off the ground, they turned failrly easily so I don't think the viscous coupler fused itself locked.
What I would like are some pictures on the front locking device and how to get the actuator pin back to where it belongs (unlocked). I saw a picture here somewhere for the rear locker but the front looks different. I have an FSM and will look it over.
One question, do I disconnect the fork off of the actuator pin by removing the screw holding them together or do I leave them bolted together and pry them back together?
Thanks.
The tires could either turn opposite or turn the same direction if the diff is unlocked. Depends on which bit of friction is overcome first in the diff. With the front driveshaft off, prevent one tire from spinning (usually done by leaving it on the ground) and turn the other one. If you can, the diff is unlocked. If you can't, it's locked.
- Spike -
Confirmed. The front is locked (one wheel up and the front drive shaft out the wheel off the ground will not turn).
Any guidance on taking apart the front locker to slide the actuator pin and fork over?
Which way is it to slide the actuator pin / fork to unlock it - to the passenger of driver side?
Thanks.
Edit : Found a picture in this thread and it says to move the gear plate towards the outer side away from the third member to the wheel
I don't remember specifics, but when I looked in mine it was pretty obvious how it worked. Open 'er up!
First I would jack up the front end. Take off the actuator plug. Have someone move wheel back and forth. tap the diff locker housing (not too crazy on the actuator motor housing...the magnets inside will come unglued) try to cycle actuator motor with fresh 9v battery only for a sec at a time (dont want to burn it up) If it does come back to life just try to cycly it for a bit with the battery. If not then you will have to take it apart. I just dove into it. Marked everything very good. take apart slow so you can see how this thing works and then its pretty basic in there.
The FSM says to lock up the front (but that is to take out the axles and the third member). When re-installing, do I slide the fork to lock the axle (towards the third member) and set the magic dial to lock FR-RR OR do I slide the fork to unlock the front (slide the fork away from the third member) and adjust the spline gear accordingly?
Look at the attached picture from the FSM. The circled picture shows the fork gear teeth in the unlocked position, I think. Am I right or wrong?
Thanks
PS Use CTRL + to zoom closer and use CTRL - to zoom out or CTRL 0 to zoom to normal size
