Stuck axle hub nut
Northwest Arkansas
Hi all, I dove into the front axle service on my '94 80 with DVD and FSM and FAQ on the axle service and have disassembled the passenger side successfully. But when I got to the drivers side to disassemble it and found the outer 54mm hub nut to be stuck. I moved the star tabs back and have the 54mm socket from Slee and a big breaker bar but still it would not budge.
i guess the question is what is the best next step in getting this off?
It's late and I need sleep so if there are ideas out there fire away and if question I'll get back as soon as possible tomorrow.
Thanks in advance, Bryan
Every time I have had this problem is has been the bent washer tabs between the two nuts and I just missed one tab. Feel around with your finger. I can't see why a breaker bar would not get this off.
If that doesn't do it try cleaning with brake fluid to better see what is going on.
You said your tired. My advise is to call it a night and you will likely figure it out quickly in the morning.
Good luck.
x2
get some sleep & look at the locking tabs closely tomorrow.
Agree to double check the locking tabs - they are not symmetric. that plus grease everywhere...
DougM
Thanks for the advice. I'll give it another shot this afternoon.
Bryan
Slight thread hi-jack, but where in Northwest Arkansas?
I grew up in the Ozarks, little town on the Buffalo National River, Jasper, AR about 20 miles south of Harrison.
Just curious.
Good luck with the outer nut. Couple of mini's and LC's and I have never seen one stuck on that bad. Maybe the PO/Mechanic cross threaded it? Let us know what you figure out.
Jack
Well
What happened. If you ask for help you must return with what happened.
Damn, and here I was thinking it was :princess:Mud~Chic`:princess: to leave all these threads hanging with no closure.
Thats because it doesn't fit well into one of those country songs you may play on your Guitar. You know like, "If you take your tongue out of my mouth I'll tell you I'm leaving." or " My girl dang left me for my brother who happens to be my uncle."
You mean like:
"Where oh where, are you tonight, why did you leave your Mud thread undone?
I searched the Board over, looking for answers,
You started another thread a thpthpthp you were gone......" :beer:
Seriously, I hate it when they never come back. Users.
Sorry for the delay guys, sister in a car wreck yesterday and I wasn't able to get to it. Okay, so tonight the nut is still stuck. Sprayed thing down and used a light to check for any stray tabs that I couldn't see before and still no luck. Maybe it is cross threaded not sure I'm really new at this. Again, soory for the delay and I don't plan to leave things unresolved. Bryan
I'm in Berryvile, a little bigger than Jasper and about 30 minutes west of Harrison.
did you feel around it with your finger for the tabs? They are very thin and hard to see.
Sorry about your sister, hope everything is OK.
To the nut is flush with the washer which is flush with the inner nut (confirm)
The tabs are all bent out of the way
Does the socket not move with the breaker bar or does it slip off the nut? How long is the breaker bar?
Do the threads look like they were cross threaded with it going on? Are they rusty? Dirty, etc?
Just drove through there a month or so ago when I was home visiting the fam damily.
Glad to hear your sister is fine.
I'm with Romer on this, there has to be some type of mechanical bond, either tabs, crossthreaded (Remember crossthreaded is better that Loctite:cool:) something. Just not sure what it could be.
Like I said, I have torn several Toyo axles apart and have never had a problem getting anything apart. One of the benefits of a gear/oil filled housing, everything stays lubed.
Good luck.
Jack
To the nut is flush with the washer which is flush with the inner nut (confirm) Yes
The socket slips off when I apply a lot of pressure
18” heavy duty bar
The nut is not dirty or rusty, but it does look beat up, I read another thread that said they thought their nut was beat off with a chisel and hammer, maybe too tight. The nut corners do not look like they are rounded and the socket doesn't slip over the corners it just slips off when I increase the pressure and the socket comes off the nut. Hope that's a better picture, I tried to take a picture but could get anything clear. Thanks for your continued help. Bryan
Crazy - two tough wheel bearing lock nuts in one month. Was it dry in there - no grease? Sorry you're having such trouble, now just trying to gather some data.
DougM
so I am getting that the socket slips off rather than you push and push on the breaker bar and nothing happens.
This has happened to me as well.
Get someone to hold the socket on the nut with both hands and push down (Toward the hub) as much as possible while you go at it with the breaker bar. If you have something longer that would be good. I sometimes (Shhhhhhh) use my torque wrench.
Good luck
