Struggling With Removing The 3rd Members
San Diego
Okay, its locked, negative terminal removed, axles front and rear removed completely, front and rear drive shafts dropped, all bolts removed, and I can't get my 3rds to budge. I've tried a floor jack with a block of wood under the drive flange and jacked it up enough to raise the rig off the jack stands. I've tapped with a 2lb hammer, and pulled both directions with a heavy duty ratchet strap, STILL NOTHING :bang:. I am missing something.....any other tip? I really wanted to deliver my 3rds to my mechanic tomorrow, SHEEEEIT!
There are probably dowels to locate the diff. Have you tried inserting some screwdrivers or similar between the housing and diff to help move it outwards?
I may be doing this soon also; post up photos of the solution if you've got any.
Don't baby those things. Drive a wedge or screwdriver between the 3rd and the housing. They'll pop out.
I tried using a dull 1" chisel as a wedge and didn't have any luck either. I guess I am doing the right things so I'll keep at it.
Just spent another couple of hours trying to get these boogers off, no luck but at least I broke the seal. Seems like the locker side of each diff didn't move though. I reconnected the negative terminal and started the cruiser up, lockers indicators both flashing. Left the engine running, inserted axles and spun 'til flashing locker lights stopped. Removed negative terminal again and shut the engine off. Still no luck. Used BFH, straps, floor jack, bottle jack on top side, even snapped my biggest screw driver trying to pry it apart. WTF?!!!
Maybe send a pm to Beno or others who've done this before. In the thread above they put a bottle jack under the 3rd to put some pressure on it then beat the 3rd with a hammer; that didn't work? Could you post up a couple of photos of what your 3rd member looks like now??
From the underside I used my 3 ton floor jack. raised it up enough for the axles to come up off my jack stands...while up I beat it with a BFH, pried it with my largest flathead screwdriver until it snapped in half, and it separated about a 1/4", that's it. Attached my ratchet strap from the drive flange on the diff to my center diff crossmember, tried to spead with a pry bar and nothing. Placed my OEM bottle jack on top of the diff to a solid member and still no luck. These are some stubborn diffs to say the least..... but i will continue to try again tomorow after work. The :beer: keeps me calm, :D.
Something is not right, after the seal is broken, they should pretty much slide right off of the studs. Are you sure you got all of the nuts? Are they tighter towards one side?
Never had issues pulling 3rds, some jiggling back and forth and before you know it you've got a 3rd on your chest, and breathing becomes difficult. Was RTV used as a gasket? Not that it should matter if you've broken the seal, just curious.
Worse case you can bodge up a puller. Get some u bolts and a decent size bit of pipe and bolt it up to the pinion flange. Then get two of the toyota screw type bottle jacks or similar mechanical type jacks on either side of the pipe, pressing against the face of the axle housing to force the diff straight out.
It almost sounds as if the axles aren't out but your first post rules that out.
You said you have a 1/4" gap space started. Go to Home Depot and buy a small crowbar. They are strong and work well in tight spaces. Another idea is use a come-along to pull the diff from the other axle. Route the cable to pull it out as straight as you can. Use the crowbar and your BFH as you pull on it.
Just some ideas.
Did you get the two nuts on the long studs that poke through the e-locker?
If your e-locker is getting hung up, you should be able to pull the motor housing off and lock and unlock manually, right?
This.
If the third member is loose from the gasket, pulling harder isn't going to help. You're going to break whatever it's hung up on. The part fits through the hole, if it doesn't something's wrong.
This sounds more like what you have to look for. Something is hung up.
VCCruzr: If you can please post up a couple of photos of where things are now and what was keeping it from coming off; I'll be doing this soon myself.
I may have missed these,:o. I will check them out after work.
Bolts through the e-locker!
BTW for future referance I use a plumbers blow torch to warm the seal, IIRC it is the same FIPG used around the sump, again a little heat and the joint 'gives'.
regards
Dave
